Author Topic: Steering Rack Boots 1974 T/C  (Read 490 times)
Offline kram350kram
« on: Tuesday,June 09, 2020, 08:08:22 PM »
Just confirming that the correct steering rack boots are Spitfire? Any particular year?  I have some weird coupling on the passengers side of the rack? Is this normal? Looks like this coupling pipe is shown in the parts breakdown but not shown where located on the rack?  Thanks in advance.
Re: Steering Rack Boots 1974 T/C
« Reply #1 on: Tuesday,June 09, 2020, 08:14:19 PM »
Spitfire boots should fit. r.d. enterprises has them and they will definitely fit.
« Reply #2 on: Tuesday,June 09, 2020, 10:18:43 PM »
The rack (externally) is basically the same used on the Triumph Herald/Vitesse/Spitfire/GT6 so they should fit.  The boot stretches over that large coupling, especially if you wipe it with grease/oil before fitting.
Getting the right size isn't difficult. I must admit I normally keep a set of "universal" boots on my shelf and that's what is on my car at the moment.  These are the same diameter as the tie rod on one end, with the rack end being a longer length with several sections of reducing diameter at the other. Select the diameter you need for the rack, cut with a sharp knife and that's it. I also use tie wraps to hold them in place.... :-[
« Reply #3 on: Wednesday,June 10, 2020, 05:46:01 AM »
That rack looks pretty tough.  I would strip it completely, chemically remove all the rust, and then evaluate the parts.
