Author Topic: Tie rod end  (Read 504 times)
Offline califkid_66
Tie rod end
« on: Monday,June 08, 2020, 09:41:58 AM »
I need to change my tie rod end but not sure about part
Number or what car and year it came from
also need a bushing in the steering rack
Just want to get the right parts
Thanks for your help!
Re: Tie rod end
« Reply #1 on: Monday,June 08, 2020, 09:52:31 AM »
The tie rod ends are from a Triumph Spitfire (as is the upper ball joint). I don't think the year is important.
Which bushing in the steering rack are you talking about? Are you planning on rebuilding or "freshening" your rack?
Offline califkid_66
Re: Tie rod end
« Reply #2 on: Monday,June 08, 2020, 10:25:26 AM »
Thanks BDA I have to change the outer bushing passenger side I feel some movement
Im gonna take it out and refresh it for now it seems to be only one bushing plus the tie rod
Re: Tie rod end
« Reply #3 on: Monday,June 08, 2020, 10:49:35 AM »
Still not sure what you mean. Is it on this diagram: https://mossmotors.com/triumph-spitfire/suspension-steering/steering-rack-2
Could you be talking about the busing inside the rack tube that supports the passenger side of the rack? I don't believe those are available.
« Last Edit: Monday,June 08, 2020, 11:04:06 AM by BDA »
Re: Tie rod end
« Reply #4 on: Monday,June 08, 2020, 10:52:31 AM »
I have 6 of those in bits in my garage.................
Offline RoddyMac
Re: Tie rod end
« Reply #5 on: Monday,June 08, 2020, 03:22:37 PM »
BDA,
The passenger side bushing is #24 on the diagram you've linked, showing that they're currently trading for $6.99 USD.
Re: Tie rod end
« Reply #6 on: Monday,June 08, 2020, 03:55:28 PM »
Ah! I stand corrected! They are available! Thanks Roddy and califkid_66, you're set.
Offline califkid_66
Re: Tie rod end
« Reply #7 on: Monday,June 08, 2020, 07:06:42 PM »
Thanks  guys that’s exactly the bushing I was
Talking about  thanks again for your help
