Author Topic: Euro TC Stromberg Intake Manifolds  (Read 1709 times)
Offline literarymadness
« on: Sunday,June 07, 2020, 02:01:59 AM »
Every since I read about them in the Miles Wilkins' book and saw them in photos on a couple this forum's member's cars, I have been wanting a Euro TC Stromberg Intake Manifold set-up. A UK transplant in France (on the lotuselan.net forum) had the pair minus the balance tube and I bought them the day they went up for sale. They finally are on my car and I took some photos of the set-up before the Air box gets put back on.
Lotus only made them for 18 months and made two types: the early Mid-Level Balance Tube version and the later superior High-Level Balance Tube version. Some of them actually were put on by the factory on some ROW (Q vin code) Europa TCs. But Lotus felt they were making too much power for the 336 transmission. But most were put on Elans.  For the record, according to the Miles Wilkins' book, the fastest Elans ever tested had Stromberg heads (high compression with Sprint Cams) and not Webers. They were only within three horsepower of the Weber and they had more torque.
« Last Edit: Sunday,June 07, 2020, 02:04:23 AM by literarymadness »
Re: Euro TC Stromberg Intake Manifolds
« Reply #1 on: Sunday,June 07, 2020, 04:13:45 AM »
Thanks for posting the pics Literary!
Have you driven it yet and noticed a difference in how it runs?
« Last Edit: Sunday,June 07, 2020, 06:00:00 AM by TurboFource »
« Reply #2 on: Sunday,June 07, 2020, 05:58:29 AM »
Just wondering, are the hoes on the top of the manifolds covered by plugs or are part of the casting.
When I had my high balance tube manifolds made, my machinist had a hell of a time trying to  figure out how to drill out the holes for the balance tubes. It takes a special right angle tube to make the hole which he did not have. He decided to finally come in from the bottom to make the hole and drill/tap threads for a plug to cover the hole. In my opinion these manifolds make for a much cleaner looking engine bay especially with tubular headers.
« Reply #3 on: Sunday,June 07, 2020, 11:19:22 AM »
@Joji:  Rather than guessing, I will give them a close examination when I go back to the shop and get back to you.  Where did you mount the throttle cable?  Your machinist did an incredible job by the way.  They look fantastic. Could you post a couple of more photos of yours, if you wouldn't mind.  I found a couple of other shots of some other Euro TC intakes online and posted them below.
« Last Edit: Sunday,June 07, 2020, 11:22:28 AM by literarymadness »
« Reply #4 on: Sunday,June 07, 2020, 11:51:46 AM »
I agree with Joji! Yours look great!
It looks like your builder used Thackery washers under you Strombergs but the nuts are tightened. The manual calls for an 'O' ring sealing the carbs to the manifold and a 0.070 gap between the "adapter flange" and the carburetor. This is similar to how Weber DCOEs are mounted only the Thackery washers are supposed to be tightened such that there is a 0.035" - 0.050" gap between the coils.(I would note that I have seen some Weber DCOEs mounted rigidly to their manifolds.) I was wondering if your builder had tightened them all the way down for a reason.
« Reply #5 on: Sunday,June 07, 2020, 12:37:11 PM »
I remember reading about "Thackery washers" a while back and never gave it another thought, but this thread made me take a look at my setup and it appears somewhere along the line my Strombergs were rigidly mounted. I've been driving in blissful ignorance that I had "frothing" in my float chambers (the supposed problem soft mounting is supposed to overcome). What are the symptoms of said frothing, and should I immediately invest in new o-rings and Thack-washers? Incidentally, it looks like the studs on my manifold aren't long enough for 0.050" o-ring gap and the "Thacks".
« Last Edit: Sunday,June 07, 2020, 12:41:41 PM by surfguitar58 »
« Reply #6 on: Sunday,June 07, 2020, 01:17:16 PM »
@BDA:  There are Triumph Stromberg gaskets between the head and the intake and there are O-rings between the carbs and the Adapter plates. The spring washers are tightened within the tolerances. Thanks for the close look.
@Surfguitar: Is there any reason you mounted the throttle cable from the top rather rather than using the hole that is through middle of the intake?
« Last Edit: Sunday,June 07, 2020, 01:25:45 PM by literarymadness »
« Reply #7 on: Sunday,June 07, 2020, 01:21:26 PM »
I didn't mean to alarm anyone! That's why I included that story about people solidly mounting their DCOEs. I think if you were having frothing problems you would be running lean and you'd probably have some spitting and popping from your carbs. If it runs good, you should be fine. As you say, unless you get longer studs, you don't have room on your studs to install Thackery washers (or their rubber equivalent) anyway.
If you're really curious about it, if you know who set them up, you could ask him about it or you can talk to Ray at r.d. enterprises or Ken at Dave Bean.
« Reply #8 on: Sunday,June 07, 2020, 01:34:48 PM »
I hadn't heard of anyone complaining of fuel frothing with Strombergs before over the years. I have no idea what the symptoms of fuel frothing might be. I'm suspecting it would be similar to fuel boil of the float bowl that my Weber on my S2 experiences from heat soak, stumbling under power until fuel starts flowing. If you haven't experienced any symptoms so far, I would hold off installing the Thackery washers until you have to remove the carbs for another reason. The only other problem I can see is vibrating parts off the carbs.
My throttle cable attachment is similar to what you have, a bracket between the two manifolds. I've attached a few photos of other versions of HBT manifolds I've found on the web.
« Reply #9 on: Sunday,June 07, 2020, 01:36:47 PM »
Just another mystery from my deceased PO.
t
« Reply #10 on: Sunday,June 07, 2020, 02:31:30 PM »
@Joji: That bracket really looks great. It looks a lot less obtrusive than mine. Did you machine that yourself?  I also actually love the red anodized version. Here are the intakes before they were shipped from France and refurbished here by Steve Smith (Twin Cam Racing).
« Last Edit: Sunday,June 07, 2020, 02:54:50 PM by literarymadness »
« Reply #11 on: Sunday,June 07, 2020, 03:53:00 PM »
Looking at the Fed-spec intake from both sides, the plumbing looks like a disaster and excessive. Now granted it was designed to reduce emissions. But you can see that all that extra plumbing did less balancing of the air flow between the two carbs and robbed power.  The engineers at the time admitted it was a rush job and they wished they had enough time make the design more efficient.
« Reply #12 on: Sunday,June 07, 2020, 09:59:30 PM »
Fuel frothing is a high rpm issue that rears its head with prolonged flat out driving.  It's not an issue in normal city and highway driving.  So, if you have mounted your carbs too rigidly, you may not notice anything until you take it to the track or climb a long steep mountain pass.  Given both Lotus and Renault engineered flex into their dual side draft carb intakes, I would make keep it!
Offline Lotuswins
« Reply #13 on: Sunday,June 07, 2020, 11:48:48 PM »
Here is my throttle cable bracket.  In fear of the side wear on a throttle cable I utilized small ball bearings on each end of a tube between the head stud holes.  Bearings are from a RC car wheel bearings, which are really small.  The tube rotates as the cable moves up/down on the throttle shafts.  So far its worked now for 20 years.....
Jerry Rude
4005R
« Reply #14 on: Monday,June 08, 2020, 01:35:27 AM »
@Jerry: Very cool solution and you were able to maintain an angle similar to the original Cam Cover cable bracket.  :beerchug:
« Last Edit: Monday,June 08, 2020, 01:37:59 AM by literarymadness »
