Author Topic: New Dashboard  (Read 2194 times)
Re: New Dashboard
« Reply #15 on: Tuesday,April 21, 2020, 04:18:44 PM »
[quote
I will post a photo of the back wired up soon, when I start after completing the "honey do" list.
[/quote]
   4129 :FUNNY: :FUNNY:  finish the honey do list..... :FUNNY:
Offline 1970EuropaGuy
    • Lotus Europa Restoration
Re: New Dashboard
« Reply #16 on: Tuesday,April 21, 2020, 04:24:07 PM »
I've been debating making my dash a more "plug in" type situation although rather than using perhaps a 30 pin connector I'll likely use a number of I think 4 pin connectors (I haven't figured this out yet!). It would be so much easier to unplug a gauge than remove a gauge.
Offline JNS
Re: New Dashboard
« Reply #17 on: Friday,April 24, 2020, 01:13:11 AM »
Thanks everyone. My crash pad is ok but I'm getting the impression this has to be removed along with the dash. Can I just remove and replace the dash? It doesn't seem too attached to the crash pad.
Offline BERNIEHUMBER
Re: New Dashboard
« Reply #18 on: Friday,April 24, 2020, 05:31:46 AM »
HI:
Yes I did it.
This was on a S2 and I was worried that there was a glued or bonded edge at the dash to the crash pad but there was not.
Re: New Dashboard
« Reply #19 on: Friday,April 24, 2020, 02:29:19 PM »
Most crash pads are stapled to the dashboard from behind.
I am currently fitting a complete new mould injected plastic crashpad instead of the Banks foam one. It is proving difficult as you have to cut the ends away to make it fit in the 50" gap between the two front window pillars. Plus you have to cut out the demister vent holes.  I will post progress when I have managed to actually fit it complete with a dashboard.
Today, after my marathon 15 day "honey do" was finished, I started wiring up the 4 new dashboards with 4 new looms. The problem is Bank's wiring diagram is hard to read as the colours are not easy to see, and he does no use letters to differentiate the colours, only the coloured wiring diagram. Some wires need extending to fit, but I completely stripped 7 old looms, so I have heaps of the correct coloured wires for extensions/adaptions. The new loom only has radio speaker wiring to one door, but who listens to a radio when driving a Europa, I would much rather hear the exhaust note.
Re: New Dashboard
« Reply #20 on: Friday,April 24, 2020, 04:56:38 PM »
  I came across this article I think you may like.
Other problems and knowledge are addressed here.
http://lotus-europa.com/nov2006.html#1127
Offline Neil D
Re: New Dashboard
« Reply #21 on: Saturday,May 02, 2020, 02:03:42 AM »
A few I made for my sons birthday. With glove box lid ;-)
2 different veneers
(he is restoring a TC / 4 speed)
Neil
Re: New Dashboard
« Reply #22 on: Saturday,May 02, 2020, 06:07:59 AM »
Very nice Neil! Don't forget to finish both sides and all the edges to keep moisture out.
Offline Neil D
Re: New Dashboard
« Reply #23 on: Sunday,May 03, 2020, 01:00:17 PM »
Absolutely, As soon as I can get some stain and marine varnish :-(
Thanks for the comment
Neil
Re: New Dashboard
« Reply #24 on: Sunday,May 03, 2020, 01:42:15 PM »
I almost hesitate to say it because I say it so often and it wouldn't surprise me if some are tired of my saying it! But I figured that it was better to be bored by a post than to miss that tip! I learned that from the guy who did my dash (prestigeautowood.com). He told me that's what he did and I was sold. He also did a fabulous job otherwise.
Good luck on yours!
« Last Edit: Sunday,May 03, 2020, 01:43:49 PM by BDA »
Re: New Dashboard
« Reply #25 on: Sunday,May 03, 2020, 01:52:12 PM »
A post about dashboards isn't complete until you've reminded them to seal the back and edges!  :)
I also repeat myself so that an important point is not missed. My daughters don't always appreciate this fine point and have been known to refer to it as senility! Maybe I should leave it more than two minutes between repeats......
Re: New Dashboard
« Reply #26 on: Sunday,May 03, 2020, 02:01:02 PM »
Quote
 :FUNNY:
Re: New Dashboard
« Reply #27 on: Sunday,May 03, 2020, 11:54:07 PM »
I'm just waiting till you offer the same advice to someone with an Aluminium dash. :)
Re: New Dashboard
« Reply #28 on: Monday,May 04, 2020, 03:05:33 AM »
 :FUNNY:
  Spot on!
  Spot on!
    :FUNNY:
Re: New Dashboard
« Reply #29 on: Monday,May 04, 2020, 05:47:11 AM »
Haha . .
Although it's probably worth noting that while the stock dash was painted brown on the reverse, I doubt it could be considered entirely sealed.
Are there many complaints of wet dashboards that I've missed?
