Author Topic: TC Throttle pedal assembly LHD  (Read 462 times)
Offline Neil D
« on: Thursday,April 16, 2020, 10:10:46 PM »
Dear all,
Would anybody be kind enough to send me the dimensions of the moiunt holes in the plenium chamber for a LHD TC Throttle pedal assembly.
Thank you very much
Neil
Re: TC Throttle pedal assembly LHD
« Reply #1 on: Friday,April 17, 2020, 07:24:32 AM »
First....  :Welcome: Neil!!!
I measured the distance from the rear wall of the front trunk to the rear most screw on the driver's side at about 4 3/8". It's actually somewhere between there and 4 1/2". The rest should follow from your throttle pedal assy. but I measured from the front wall of the trunk to the front most screw anyway at 9 7/8".
Measuring the side dimension is difficult since the side walls are not perpendicular to the front or rear. I think the part that houses the cable should be positioned against the tunnel and so should locate it side to side.
Does that help?
« Reply #2 on: Friday,April 17, 2020, 10:51:55 AM »
Another  :Welcome:
Are you asking for the dimensions between the bolts or the actual physical location of the four holes in the plenum area.
The long spacing between the bolts is 8-3/8", the short spacing is 5". the holes appears to be square to each other with the diagonal measuring 9-5/8".
Offline Neil D
« Reply #3 on: Sunday,April 19, 2020, 10:14:08 AM »
Thanks for the welcome
Used to be in the lotus forums in the early 90's convetinga nd S2 from RHD to LHD
now helping my 20 year old do the same with his TC
Thank you for the information
Neil
