Author Topic: Unobtanium  (Read 7430 times)
Offline Chuck Nukem
Unobtanium
« on: Friday,March 20, 2020, 09:28:05 AM »
Hey guys,
I figured this would be a good place to consolidate all the common unobtanium parts for all series of Europa.
Ashtray
Door latch mechanism for S1, S2, TCS
Rear tail lights S1
365 Transaxle parts
What else is hard to come by?
Re: Unobtanium
« Reply #1 on: Friday,March 20, 2020, 09:33:46 AM »
money -  when your other half realises what we're spending ?   :)
Re: Unobtanium
« Reply #2 on: Friday,March 20, 2020, 09:47:14 AM »
Smiths squirrel cage heater motors/blowers.
Seat shells for TC.
Weber heads.
Door window motors.
Inertia seat belts.
9mm bolts gear-change rod to gearbox selector rod.
Re: Unobtanium
« Reply #3 on: Friday,March 20, 2020, 09:47:52 AM »
 :FUNNY:
Re: Unobtanium
« Reply #4 on: Friday,March 20, 2020, 06:08:06 PM »
  4129 , If Needed , pA member on Instagram said a better fan assembly is a lotus Elise/ exige s2. Also quieter and more cfm . I understand the originals are rare.
  Speedo gearing or cable,   I’ve heard something about.
« Last Edit: Friday,March 20, 2020, 06:11:53 PM by dakazman »
Re: Unobtanium
« Reply #5 on: Friday,March 20, 2020, 07:30:10 PM »
For me it's
#1  Door seals that fit and work...I have tried just about every source.
#2 Original windshield trim with corners for the TC...Installed last mfg set from Japan 8 years ago via Ray at R &D hope it lasts another 40.
#3 I have a spare squirrel cage...whew!
#4 Factory tool kit with tools, Jack and bag with spare wheel strap.
« Last Edit: Friday,March 20, 2020, 08:55:26 PM by Lou Drozdowski »
Re: Unobtanium
« Reply #6 on: Friday,March 20, 2020, 11:16:18 PM »
4129R, you can get weber heads from QED. Ok, they are selling the casting for theElan/Ford installation but the only difference AFAIK is the extra long inlet cam which requires machining for the seal arrangement. Not a big deal considering all the other machining that's going on anyway.
https://qedmotorsport.co.uk/product/cylinder-head-small-large-port/
(I didn't say you'd like the price though.....  ;)   )
Re: Unobtanium
« Reply #7 on: Saturday,March 21, 2020, 12:38:31 AM »
....they are selling the casting for theElan/Ford installation ....
There is a Europa option in the drop-down box at the bottom for an extra £75...
Re: Unobtanium
« Reply #8 on: Saturday,March 21, 2020, 12:54:56 AM »
I hadn't noticed that option and to be honest, £75 doesn't sound out of the way.  There's a guy on the Elan forum that's used one of these castings to rebuild his engine and by his accounts it's a quality item.
Re: Unobtanium
« Reply #9 on: Saturday,March 21, 2020, 05:41:58 AM »
I got a new one from QED for my keeper. Unobtainium is expensive.
I have bought several second hand heads, and all needed work plus the inlet cam groove cut near the alternator pulley wheel.
Re: Unobtanium
« Reply #10 on: Saturday,March 21, 2020, 05:53:43 AM »
The rubber mesh material in the seats?
Re: Unobtanium
« Reply #11 on: Saturday,March 21, 2020, 06:34:10 AM »
Boy Turbo, that's a strange one to think about! You're almost certainly correct. When I had my seats redone, the shop replaced that with cloth webbing.
I would put that in the same category as front A-arms, outer seatbelt anchors, and TCS trim pieces. They are no longer made but replacements or reproductions are available.
Re: Unobtanium
« Reply #12 on: Saturday,March 21, 2020, 09:52:41 AM »
Those little round door light switches.
Offline Nockenwelle
Re: Unobtanium
« Reply #13 on: Saturday,March 21, 2020, 04:41:54 PM »
The Europa S1 is full of unobtanium parts:
- Carello tail lights
- Oddie hood faster (push style) engine bonnet
- Oddie fasteners (locked with key) front hood
- speedometer and tachometer (they were bigger than the later ones)
- seats
- single piece fixed side windows made of glass (not all were plastic)
- seat belt assembly
- dash air vents, unfortunately those are the same as the ones used on the Miura
- early 336 gear boxes were different too (different shift pattern
- luggage tray with battery compartment
- 4.5 steel wheels
Re: Unobtanium
« Reply #14 on: Saturday,March 21, 2020, 05:09:16 PM »
Quote
That's REALLY something when you might have to rely on a Lamborghini model that ended production 47 years ago after a run of 764 cars for a part!!!
Speaking of dash air vents, is there a supplier or replacement for the dash vents on a TC (are they the same as on an S2?)?
