Author Topic: TCS Valve Adjustment Question  (Read 1378 times)
Offline Fotog
  • 72 Twin Cam
Re: TCS Valve Adjustment Question
« Reply #15 on: Tuesday,May 12, 2020, 05:27:35 AM »
OK; thanks John.  I'll give a go at that.  This IS a little disconcerting!
-V
Offline Fotog
  • 72 Twin Cam
« Reply #16 on: Tuesday,May 12, 2020, 01:07:25 PM »
I did it.  A little trickier than I had hoped, but I think I got it.  I had to jigger the position of the exhaust cam a bit to get the sprocket aligned with the dowel.  It would be "almost right", then I would find that I needed to create more slack from the intake side (apparently slipping one tooth on the exhaust side (again!)) etc.  For a while I was carefully keeping track of how many teeth I moved the chain.  But ultimately I felt like I knew what I was doing and just kept moving things until I got the correct result.  (I hope!) Marks on the sprockets are where they were at the beginning and cams in their same positions.  All while the crankshaft was in TDC position.
It seems that the chain tends to slip its position relative to the teeth on the crank sprocket pretty easily (despite my attempts to prevent that), but it doesn't fall to the side, luckily.
I still need to loosen/remove the intake camshaft to change the oil seal, and button things up.  And I will need to re-orient the distributor so the cap screws are still accessible when I re-set the timing, but I've done that before, so I'm not concerned about that.
I've read plenty about sealants for the valve cover.  It seems like everybody has their favorite methods and probably many are similarly good, but I plan to adhere the cork gasket to the cover with silicone and then just put it on the head with a smear of grease.
It's all a matter of going through things once and becoming familiar with what's involved.  Especially when you can't see all the mechanical parts.
Vince
« Reply #17 on: Tuesday,May 12, 2020, 01:13:38 PM »
Quote
+1 That's my preferred method for cork valve/cam covers.
« Reply #18 on: Tuesday,May 12, 2020, 03:36:52 PM »
After everything is together, before the valve cover goes on,  adjust the cam chain tension and turn the engine over two complete revolutions if the crank by hand tools on the crank pulley nut.  Everything all lined up again?  Cam chain tension ok?  Now you are ok to fit the valve cover.
Offline Fotog
  • 72 Twin Cam
« Reply #19 on: Tuesday,May 12, 2020, 06:16:11 PM »
Ok.  Thanks for the advice.  Hand tools as opposed to turning a wheel, so I can tell if something interferes (god forbid)?
I think I ultimately moved the chain by 5 links.  Just re-reading initial advice from you and Brian, I see that you mention that it's often the case that the chain comes off of the jackshaft sprocket.  I somehow had the feeling that my issue was at the crank sprocket, but I guess I'm really not sure.  This is where those x-ray specs would come in handy.
-V
Offline Fotog
  • 72 Twin Cam
« Reply #20 on: Thursday,May 21, 2020, 05:21:14 PM »
I got it all back together.  Everything checked-out fine.  I re-set the distributor position and set the static timing.  Sealed it up, and started it.
Problem!  I apparently over-tightened the distributor pulley bolt and popped the split ring behind it part-way off.  Not knowing, I damaged my new oil seal on the intake camshaft when I ran it.
Oh, well!  Live and learn.
Question:  Is there a torque spec. for this somewhere that I didn't see?  I know that I torqued something in a 5/16-24 size to the general number after not finding a spec, but I don't recall what it was.
Is this a place where blue Loctite would be advisable?  It seems so.
Vince
« Reply #21 on: Thursday,May 21, 2020, 05:48:35 PM »
Poop!
You are just snugging the pulley against a circlip/split ring.  Don't use generic torque recommendations in this type of situation as they are based on clamping force against something that is solid with the concern being when the threads will fail.  Shouldn't need loctite but a little bit of the blue (medium) would be fine.
Offline Fotog
  • 72 Twin Cam
« Reply #22 on: Thursday,May 21, 2020, 06:46:21 PM »
Poop!
Yeah, really!
Quote
Righto!  I should have thought that through better.  But I'm  surprised that they don't give a torque spec for this so as to avoid a mistake like I made.  That said, the manual is pretty good.
-V
