Hopefully the body will be lifted on to the chassis soon.
Just trying to figure out if I have forgotten anything...
Chassis is done including the padding. Steering rack is mounted but not master cylinder. It's a very early S2 and they had S1 brakes.
Engine and transmission is there as well but not manifold. No wire harness in the car. I have a new one and will fit that when the body is on the chassis. Clutch cable and speedometer cable will also be fitted afterwards. I guess that's possible. I think the chassis is in the same state now as it was when I lifted the body off the chassis
Trying to make sure I don't need to remove the body again...
Will clean up the threads for the bolts holding the body to the chassis. Not sure what else is needed before I put it together? New water pipes is in place as well as the smaller pipes to the heater. The rest of the heater stuff will be done later. Can't think of anything else. What do you think?
