I have sanded the entire body and covered it with thin fiberglass veil (30gr/m3) to seal all micro cracks. Turned out very well!
The body, doors and bonnets will go to the painting guy in four weeks
Color will be L05 Carnival Red as the VIN plate says. With clear coat. Wheel wells and underneath will be black body and engine compartment, front compartment (where the spare wheel sits) and underside of bonnets will be satin black.
This is a restoration to how it was when new, so no modifications at all (except the spray body under the car and the painted gearbox and engine as that's just to be able to keep it to a nice standard for longer). This means that I will keep the Solex DIDSA2 carb. No one makes gaskets or a overhaul kit for that carb as it seems that the only car that had that Solex was Europa 1470cc. Not even the Renault where the engine came from had that carb. I finally found a rebuild kit for a Solex fitted to some BMW from the seventies. Most parts seem to be the same so I will be using those.
