Author Topic: Half-shaft u-joints 1974 TC Special  (Read 462 times)
Offline kram350kram
« on: Monday,January 20, 2020, 07:50:51 AM »
Any opinions on best/strongest u-joint for half-shafts, 1974 TC Special? Thanks in advance
Re: Half-shaft u-joints 1974 TC Special
« Reply #1 on: Monday,January 20, 2020, 07:59:24 AM »
I have used and like SKF, Spicer and GKN.  Don’t use GMG.  This is more of an issue with the smaller u-joints for the S1/2.  TC/S joints are larger and last longer.
« Reply #2 on: Monday,January 20, 2020, 08:09:28 AM »
I have read and think Hardy Spicer U joints are the best.  I also use Hardy Spicer grease.  A lot of the greases are  too thin and sling out of the bearing cups.  I bought my u-joints from englishparts.com.  P/n 18110, at least for a tcs.  They were $23 each.  The grease is Hardy Spicer SPL 1051.  I had to install longer grease fittings than were supplied to get my grease gun on the fitting.
