Author Topic: Cam Shaft Pulley  (Read 776 times)
Offline Bart
Cam Shaft Pulley
« on: Wednesday,January 15, 2020, 07:22:43 AM »
Good morning all,
I need to buy/make a cam shaft pulley that turns the belt to drive the alternator, as I don't have the original pulley I was hoping someone could let me know its outside diameter and belt section/profile. I wanted to use an aluminium pulley to reduce the rotating mass, RD has them on their site but has no stock or plans to get more and Banks only have a 4" diameter one that will turn the alternator too slowly (or at least slower that the original).
I measured the shaft and its 7/8ths with a keyway, McMaster has a cast aluminium pulley at 4-5-6-7" OD for a 7/8ths shaft that will take 3L or 4L section belts not sure this is suitable or will work...
As usual thanks for any help.
Re: Cam Shaft Pulley
« Reply #1 on: Wednesday,January 15, 2020, 08:10:35 AM »
Bart,
I assume you have a twincam engine.
I have an oem pulley I am willing to part with.  It is 7” in diameter and has a keyway in the approximately 7/8” bore to fit the cam.   An off the shelf pulley will need some machining to fit on the cam properly.
Let me know.
« Reply #2 on: Wednesday,January 15, 2020, 09:05:46 AM »
There was a guy on the yahoo group who made them for several TC owners. He did a great job. He even made a custom one for my engine (see attached photo). I don't know if he's still doing them but you can email him at markdinkens2000 at yahoo dot com.
« Reply #4 on: Wednesday,January 15, 2020, 01:41:41 PM »
Aren't the aluminium ones for the crankshaft, the ones at the front of the engine driving the waterpump ?
« Reply #5 on: Wednesday,January 15, 2020, 02:02:40 PM »
The link to the aluminium pulley is indeed for a crankshaft pulley.  The top link is to the pulley he is looking for.
Offline literarymadness
« Reply #6 on: Wednesday,January 15, 2020, 02:39:12 PM »
I removed it. Sorry My mistake!
« Last Edit: Wednesday,January 15, 2020, 02:40:56 PM by literarymadness »
