I have a custom Power Flow Exhaust system on my TC Europa. It’s all SS and made in the UK (in the town of Hethel were Lotus is located). As my engine was built by Quicksilver Racing I wanted the best header design and silencer design for this 147 HP engine. It performs the way it’s supposed to and sounds great. Here is a walk around video with the engine running:
https://youtu.be/dlaZESDiYesAnd a video of just the engine running:
https://youtu.be/lS0AfcUOkK0Regarding ceramic coating, I typically coat all my headers on my rebuilds but didn’t have it done on my Europa as there was plenty of airflow around the headers to keep them cool. As all SS rusts after a number of heat cycles, I should have had it ceramic coated.
I’m in the midst of sending out my SS headers for my 05 Elise to Jet Hot to be ceramic coated. It’s costs $225 for a typical small header.
In my 64 Elan S1 with a Quicksilver Racing built engine the Jet Hot ceramic coated header reduced the engine bay temp by 30 degrees (you can barely see the black Jet Hot coated header in the Elan engine bay picture, but it shows how tight the fit is and how important it was to reduce engine bay temp). Plus the header will never rust and is far better than wrapping the header.
I also had the custom 2bular headers ceramic coated by Jet Hot for both my Lotus Exige S track cars (see attached photo of engine with the rear clam off). I’m a big fan of ceramic coating as it works extremely well in reducing engine bay heat load and protecting the finish of very expensive headers.
With regard to ceramic coating not lasting, it’s important to note that you need to have the headers coated when new. I’ve only ever used Jet Hot and never had a problem with their coatings under pretty severe heat loads of track cars.
