Author Topic: Halfshaft shimming (again)  (Read 1988 times)
Re: Halfshaft shimming (again)
« Reply #15 on: Saturday,October 26, 2019, 08:20:28 PM »
Popping out of gear means wear to whatever holds it in gear.  Check your indent balls and springs, indent ramps on the shift rods, shift forks and the splines on the gear and synchro-hub "slider".  If it jumps out very occasionally, you might be able to repair it inexpensively.  If it has been jumping out for a long time, then you'll need to change expensive, hard-to-find bits like the synchro-hub and/or the gear itself.
What causes it in the first place?  Usually not be able to engage the gear fully and properly.  Often this is caused by something blocking the linkage, misalignment, etc.  With the gear not fully engaged, it can vibrate out.  This often wears a tapered ramp in the gear and sychro-hub "slider" splines.
The key is to catch it before the damage starts.  Always make sure you have full engagement.  Do not ignore isolated incidents.  Find and fix the problem before it gets serious.
« Reply #16 on: Sunday,October 27, 2019, 03:16:04 AM »
Tom, third gear places the shift tube up against the speedo cable. Are you sure the shift tube is adjusted correctly? If it is assembled at the incorrect angle it could be just going into third gear but not entirely due to hitting the speedo cable.
You might remove the cable from the transaxle (zip tie it to the trans support) and try driving the car in third gear.
Just a thought.
