:newhere:Well, actually hi to some of you, the rest will recognise me from a few years on the Yahoo site.
I'm UK based, Shrewsbury for those who live over here, and a I confess a very long time Europa owner, nearly 43 years, the same S2 type 54. Now retired from my job as a mechanical engineer the Europa has long been relegated from daily driver to hobby and continues to keep the technical side of the brain active.
Changes over the years
Engine 697 > 843 > + EFI > MGF 1.8VVC
Gearbox 336 > 395 > NG3-099
Suspension now has radius arm supplanting the driveshaft as upper link, otherwise quite standard layout with marginally stiffer springs and Protech dampers.
Brakes now vented discs at the front and solid MGF sourced discs at the back with 2psi residual pressure valve in line
A plywood splitter at the front has proved very effective at keeping the nose down
An undertray at the rear with diffuser is as yet mainly untested, been very busy extending my workshop and there's not been time.
Miscellaneous stuff includes a very thorough review of the steering compromising:
Replaced the rubber grommet based UJ with a steel one
Carefully adjusted the steering rack preload, only to discover it really needs a redesign per the TCS rack. Long story, too long.
Fitted spacers between the front hub taper roller bearings, this stopped the car tramlining on road imperfections also removing an elusive rattle.
MGF 15" wheels with 195-50-15 tyres, wheels centred on spigots added to hubs
Done one club Lotus track day at Castle Combe, but otherwise it's a road plaything
That's about it, looking forward to exchanges, I see there are one or two members not far from me, makes a change from most being an ocean apart.
