Author Topic: New member  (Read 1497 times)
Offline Broadside
    • Midland Race and Rally
Re: New member
« Reply #30 on: Monday,October 07, 2019, 11:37:29 AM »
Probably only stunted together at the time the pic was taken but worth checking that the handbrake cable is through the other slot at the front of the chassis - in the pic it’s routed through the wrong one and hooked onto the translator which will make it rub on the chassis and not move smoothly.
Obviously, since that pic was taken the body has been put in place so the translator would have been removed to do that but if it’s been put back in place to retain the cable end from falling back inside the chassis then it’s worth checking?
Looks like someone has done a nice job so far though, look forwards to seeing it on the road!
Thanks for that, I'll make sure I check that when I start work on it - which may be a while yet as my workshop is jammed full at the moment and I dont want to start until I can spread everything out to asses it all
Offline Broadside
Re: New member
« Reply #31 on: Monday,October 07, 2019, 11:41:48 AM »
I meant to say that the stainless transfer pipes are very cool!  :beerchug:
Mmmmm.... I haven't looked at them yet but they ought to be ali really - weight!!! and they need the ends rolling. I can see me taking it all to pieces again!!
Offline Broadside
Re: New member
« Reply #32 on: Monday,October 07, 2019, 11:43:33 AM »
...I build race cars for a living ...
So, just another boring desk job?
Well I'm only at the bottom end really but I'm happy in my work and it beats doing a proper job  :beerchug:
Re: New member
« Reply #33 on: Monday,October 07, 2019, 12:03:52 PM »
Quote
If you roll the ends, you may not be able to get them into or out of the frame. I've never seen any that had been rolled and I've never heard of a problem. Save your self some time and hassle.
