Author Topic: TCS Steering Column Shroud  (Read 1257 times)
Re: TCS Steering Column Shroud
« Reply #15 on: Saturday,September 21, 2019, 02:31:09 AM »
Have you had a look at plastic pots in a garden supply? material would be thicker, and you could form with a heat gun. (just a thought)
« Reply #16 on: Saturday,September 21, 2019, 04:13:21 AM »
I covered the bottle with silver foil tape, then clingfilm.
I have started the layers of fibreglass. It is not an easy shape to build.
To get the bottle to stand upside down, I core drilled a hole in a short piece of 7" x 2" I had lying around, so the bottle stays exactly still upside down.
I am waiting for the bottom to set before starting on the sides very soon.
Messy business.
« Last Edit: Monday,September 23, 2019, 03:06:06 AM by 4129R »
« Reply #17 on: Monday,September 23, 2019, 03:03:11 AM »
It seems to have worked.
The clingfilm stuck a bit to the fibreglass, but a few minutes with a battery drill and a round wire brush cleaned up the inside and outside very well.
I have since glued 5mm foam to the outside and will be covering with black leathercloth next weekend.
« Last Edit: Monday,September 23, 2019, 03:05:18 AM by 4129R »
« Reply #18 on: Monday,September 23, 2019, 06:12:53 AM »
That came out pretty good! Please post the finished product.
« Reply #19 on: Monday,September 23, 2019, 06:25:33 AM »
I’m impressed! Nice custom work!
« Reply #20 on: Thursday,October 03, 2019, 01:52:37 PM »
Sorry to bring us back to old posts but I'm looking at SQB190s (windshield wiper/washer) and they are all upside down for us in the colonies (or they are for the left hand side of the steering column). Is there a way to adapt them for use on the right side of the steering column?
