Author Topic: Electroplating  (Read 2118 times)
Re: Electroplating
« Reply #15 on: Thursday,September 19, 2019, 05:50:17 AM »
   :FUNNY:
   It’s not difficult to go through the steps. Time to prep the part to a smooth , pit free surface is labor intensive. I probably could have purchased the rocker cover bolts , that were vice gripped to death, but instead filed, and sanded out to 400 grit . As a test , I was happy with results.
  The copper bath was not so durable. Buffed off the finish, but as a prep for additional plating, it would definitely work.
  The zinc anodes that I purchased were not pure and dissolved quickly. A test of the plating worked however to dull for my taste. Much happier with the nickel , for the same prep.
Re: Electroplating
« Reply #16 on: Wednesday,October 16, 2019, 01:14:50 PM »
   EZ QuickStart:
   https://youtu.be/G-PtnwtOR24
My results after two weeks of playing around.
« Last Edit: Wednesday,October 16, 2019, 01:21:30 PM by dakazman »
Offline Rosco5000
Re: Electroplating
« Reply #17 on: Thursday,October 17, 2019, 10:51:15 AM »
Oh wow, I know what I am learning to do next.  Awesome work guys!
R
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
Re: Electroplating
« Reply #18 on: Friday,October 18, 2019, 10:23:51 AM »
Brilliant job on the clutch stuff, Dave.
I presume that's nickel? I wonder how nickel would hold up when exposed to the elements externally - or perhaps that's an area best left to zinc.
The YouTube vid makes it look quite doable, too.
Re: Electroplating
« Reply #19 on: Friday,October 18, 2019, 01:50:13 PM »
   Yes ,Nickel .
  Certified mentioned he used this process on his Elan build . It must have lasted or he would’ve played his bolts . I don’t know but the worse that could happen is it goes back to looking like it did before.
Time will tell .
