Author Topic: Wiring gages  (Read 889 times)
Re: Wiring gages
« Reply #15 on: Wednesday,September 04, 2019, 01:57:15 PM »
Ok. I didn't realize you had a relay and To compound my error, I was looking at the TC wiring diagram! I figured the PO had monkeyed with your wires. Well he did but I think he meant to use the purple wire correctly. JB has it right. A purple wire should be fused and hot all the time but the PO mounted the wire on the wrong side of the fuse!
I don't have a good frame of reference. I wouldn't think that some corrosion on the fuse block would cause enough draw to melt your wire. I certainly could be wrong, but I'm thinking there is a short somewhere. Maybe the relay?
Offline califkid_66
Re: Wiring gages
« Reply #16 on: Wednesday,September 04, 2019, 03:30:25 PM »
Im gonna put a modern relay  and i saw some original style fuse box and they are very affordable so either clean up the old one or get a new one
I still have to find purple wiring
Re: Wiring gages
« Reply #17 on: Wednesday,September 04, 2019, 03:59:00 PM »
http://www.britishwiring.com
https://www.autosparks.co.uk
If there is a British sports car repair place nearby, they may have an old harnesses around they can cut up.  We had a box full of them.
Offline califkid_66
Re: Wiring gages
« Reply #18 on: Wednesday,September 04, 2019, 04:23:14 PM »
ok now i feel pretty stupid
Im there thinking where can i get quality wiring to replace the bad one and im running around all day
and then i realized i have a complete aftermarket wiring harness made of high quality material
just waiting to be used and the wires are extra long multiple colours so i can cut the gage and colours i need to fix the damaged ones
I just noticed i got purple 12 and 14
« Last Edit: Wednesday,September 04, 2019, 04:35:09 PM by califkid_66 »
Re: Wiring gages
« Reply #19 on: Wednesday,September 04, 2019, 08:21:15 PM »
Excellent!
