So I've had chance to drive it a bit more.
The clutch is slipping when you give it some beans in 3rd and 4th and it's just started crunching the gear when I select reverse, as if the clutch isn't disengaged properly, though it doesn't seem to drag. I guess it's possible the crankshaft oil seal is leaking into the bell housing. Could it then get onto the clutch and cause the slipping? It does seem to recover when you ease off and only do it when the engine is hot. The car milometer shows just over 62k miles so it could just be on it's last legs. Is there a way of checking plate wear via an inspection hole? or does the engine and transaxle need to come out to check it?
Oil level doesn't seem to be going down, though I've probably only done about 100miles since I got it. It's only got minor incontinence, a few drops from the bottom of the sump and the left hand side of the transaxle I think.
Pretty convinced the bushings will be missing at the bottom of the gear lever, just by the amount of slop, and the way the gear lever rotates! I also need to check the bushing where the two selector shafts meet. I was told the rear section was replaced by one from Banks.
Hopefully this weekend I'll get chance to check clutch adjustment, get the back up on axle stands and check out the rear brakes. I'm not overly happy with only an inch or so of "bite" in the brakes at the bottom of the travel!
While it's up in the air I also intend to get some gunk onto all the oil and muck on the engine and transaxle and pressure wash it off. If I get it clean enough I may be able to get a better idea where any the leaks are.
I also need to try and clear organise my garage a bit more so I can fit in some more equipment (and have room to work).
Then get online and buy some more stuff!
