Hi Richard and
Wow, that is a very clean looking car, it doesn't look to have been overly "improved" over the years so I'd call that an excellent find. I always like the black cars, I think the colour suits the Europa very well.
I'd echo JB's points on the carb mounting, every book I've read on the topic instructs that they have flexible mounts. If you're unsure of the age then I think I would replace the O rings, or at least remove and take a look. They aren't subject to a lot of heat there so the rubber normally stays flexible for many years.
My slight twinge of concern is if they are OEM then they'll be 40+ years old, and that's a long time for rubber to stay soft & flexible. If they are too hard and you slacken the washers off to get some movement then there's the chance of leaks; air leaks are a nuisance but petrol leaks aren't so helpful !
Access underneath isn't good so I made a cut-down spanner, probably only a couple of inches long because you don't need a lot of force on the nut. That, in conjunction with a lamp up top and a small mirror underneath gives a good view of the lower washers and makes setting the gap easy.
Also if they are Dellortos and have stood for years, watch for leaks from underneath as you re-commision the car and get some miles on it. Mine developed a split in the lower diaphragm after it had stood for too many years, which resulted in petrol weeping out. Again a personal thing and definitely not a panic "you must do this now !", but a rebuild kit is cheap enough, covers all the bases and leaves you with carbs that you know are set up correctly.
