Author Topic: S2 frame bulkhead cutout correction.  (Read 635 times)
« on: Thursday,August 15, 2019, 12:52:35 PM »
S2 Frame Bulkhead correction.
 As I was going over the installation of the cooling tubes I found a helping hand pdf on what went where template. After installing the tubes and looking for something else to put together, Certified was installing his choke cable and I was making a stainless bracket for the cables. That’s when I noticed the pdf was incorrect. The two holes for the choke and heater were missing.
 So which be is choke / heater or heater / choke ? See pictures.
I will post a new pdf as soon as I get a few replies.
Re: S2 frame bulkhead cutout correction.
« Reply #1 on: Thursday,August 15, 2019, 01:45:14 PM »
I can't help you with where to route the choke and heater cables but I would advise you to use grommets around your transfer tubes where they go through the frame. They'll likely bang around and possibly contribute to damage to the tubes and/or the frame.
edit: looking at it more closely, I think I would use the hold reserved for the vacuum hose (if not equipped and I don't know why you would need a vacuum hose going toward the front of the car).
« Last Edit: Thursday,August 15, 2019, 01:50:54 PM by BDA »
« Reply #2 on: Thursday,August 15, 2019, 05:16:55 PM »
 Pacing myself, BDA. Lol it’s been way to hot and rainy lately to work in the garage.
« Reply #3 on: Thursday,August 15, 2019, 06:26:03 PM »
Dave, the top two small holes are for the heater cable and choke cable. Put grommets in them first.
« Reply #4 on: Thursday,August 15, 2019, 06:50:18 PM »
Certified, Yes , I read your post. That’s what got me going on the drawing. Those holes weren’t even on the print that was on lotuseuropa . Com. . I bent way down and there they were just as you said.
So choke left ,heater right. Hmmm I wonder if right hand drive it’s the opposite?
Offline BobW
« Reply #5 on: Friday,August 16, 2019, 06:34:11 PM »
I'm pretty sure that on my car it's heater left, choke right. But I'm not home so I can't look :(
« Reply #6 on: Friday,August 16, 2019, 07:15:49 PM »
My car is heater left choke right, which is the orientation of the devices they attaché to.
