Author Topic: Request engine bay pictures  (Read 1387 times)
Offline Lyngeled
« on: Friday,August 09, 2019, 12:31:09 AM »
Hello
Can anyone post pictures of an original S2 engine in bay? I. Like to see how it looks. Mine is not all original.
Thanks
Re: Request engine bay pictures
« Reply #1 on: Friday,August 09, 2019, 04:37:28 AM »
Bobbie, not the original finish but this is the structure. Less the firewall.
 Now can we see yours?
Offline Lyngeled
« Reply #2 on: Friday,August 09, 2019, 04:47:36 AM »
This is before it ran. The orange paint on the rocker cover fell off  >:D
Offline Lyngeled
« Reply #3 on: Friday,August 09, 2019, 04:49:23 AM »
It's empty! 😊 I meant with an engine 😁
« Reply #4 on: Friday,August 09, 2019, 05:05:46 AM »
Lol ...I’m working on it as fast as I can.
 There are plenty of pictures on Pinterest  I have Chevy orange in my Elky 👍👍
What  model crossflow is in there?
« Last Edit: Friday,August 09, 2019, 05:16:23 AM by dakazman »
Offline Lyngeled
« Reply #5 on: Friday,August 09, 2019, 07:04:26 AM »
It is a tuned Renault 807.
Offline Chuck Nukem
« Reply #6 on: Friday,August 09, 2019, 09:00:07 AM »
Dakazman your engine bay looks phenomenal! I have been thinking about smoothing mine...The decision has been made....
« Reply #7 on: Friday,August 09, 2019, 10:53:10 AM »
These are pictures of 1098R with I believe a Weber 32/36, everything else should be mostly original.
Fallbrook, Ca
« Reply #8 on: Friday,August 09, 2019, 11:32:22 AM »
This is all I’ve found .
Bobbie, Your 807 is the look That will closely resemble my 843 build. Right now just the federal wedge engine for now.
Duke, Thanks. Imitation is the best flattery. 😁
Offline 1970EuropaGuy
    • Lotus Europa Restoration
« Reply #9 on: Friday,August 09, 2019, 01:04:15 PM »
A few images of my engine bay before I painted it. I believe it's stock except for the Webber carburetor and my battery fill switch.
« Reply #10 on: Friday,August 09, 2019, 01:29:47 PM »
I checked a number of reference books and I'm not sure the level holding the cover open should be blue-grey.  I think it should be more of a grey-blue...
« Reply #11 on: Friday,August 09, 2019, 01:36:40 PM »
I was wondering about that too but I thought the correct implement was a broom handle! But then, I don't have an S2.  :)
« Reply #12 on: Friday,August 09, 2019, 04:30:51 PM »
This is the special limited edition cover support, only an option with yellow Europa's. Very rare, one of ten I believe although they are available aftermarket at Canadian Tire..
We wouldn't want our beloved Europa's parked at an angle, would we?
« Reply #13 on: Friday,August 09, 2019, 04:33:03 PM »
Here's another aftermarket cover support.
Offline BobW
« Reply #14 on: Sunday,August 11, 2019, 01:43:16 PM »
This is likely as original as you'll get here. The braided stainless fuel line was originally rubber? and there was no in-line fuel filter. There is a non-original quick-disconnect on the positive battery terminal.  A sheet of fine mesh aluminum screen is missing from the firewall, where it went on the outside of the matting you can see. The hose clamps on the heater hose should be of the same type as the one on the hose to the coolant tank. There were decals on the air cleaner.
