Author Topic: Reducing Vehicle Weight  (Read 4233 times)
Re: Reducing Vehicle Weight
« Reply #45 on: Monday,September 16, 2019, 01:10:30 PM »
I got an aluminum flywheel from Dave Bean many years ago. I'm sure they still sell them.
Offline literarymadness
« Reply #46 on: Monday,September 16, 2019, 01:17:34 PM »
Just got back from Pfreen's house.  My TCS with a 1/3 tank of fuel came in at 1491 lbs. without the spare (30lbs) and rear tub and air filter housing (16lbs.).  I have a 4 speed, aluminum radiator, aluminum flywheel, alloy rear shocks, gear reduction starter, and a 4 1/2 lb. battery.  93 octane with 10% ethanol weighs 6.37 lbs. per gallon, so about 32 lbs. of fuel was in the tank.   And yes Dave Bean still has a few aluminum radiators in stock.
« Last Edit: Tuesday,September 17, 2019, 08:53:08 AM by literarymadness »
Offline Nockenwelle
« Reply #47 on: Friday,September 20, 2019, 12:55:54 PM »
I put my fully original S1 on racing scales today. With a tank half full of fuel, luggage tray and spare wheel it weights just 610 kg.
I'm pretty happy with the result  :)
« Reply #48 on: Friday,September 20, 2019, 05:37:16 PM »
At 1387 lbs  /610 kg , with a spare, you should be happy.
  How much does a 4 speed weigh?
  How much does a 5 speed weigh?
 Aluminum radiator?
Steel or mag wheels?
Then the real question is what is the power to weight ratio. Most builds nowadays have increased their hp and their torque. I understand add lightness, but to what point. I lift my engine but myself and I’m disabled. The frame is heavy but it might take some lightening holes. The cracks that may happen over time are not worth the weight savings.
   There isn’t much more weight items other then battery , rugs, glass, seats, shocks are a big savings. The firewall material is another saving area.  Tire size another biggie. Headlight assemblies glass and bumpers ,easy 30- 40 lbs. mufflers have a big range in size and weight. Having two gas tanks add a lot of weight.
   Some of our builders have v8 in there cars , I just can’t imagine that ride. So adding hp and torque
Have the advantage in my opinion. I really would like to see an all electric Europa.
