Author Topic: Electric Fuel Pump wiring  (Read 2196 times)
Re: Electric Fuel Pump wiring
« Reply #15 on: Thursday,August 08, 2019, 11:02:47 AM »
You have to be careful with soldering where there is vibration.
« Reply #16 on: Thursday,August 08, 2019, 11:04:01 AM »
You have to strip the insulation off, crimp and then either insulate the terminal with heat shrink or a sleeve.
« Reply #17 on: Thursday,August 08, 2019, 11:41:35 AM »
That looks like a really great crimping tool!
I'm guessing that for insulated terminals, the insulation would need to be pushed up the wire, then the terminal is crimped and then the insulation would be pushed back over the terminal. Right?
I bought the Teng crimper because that’s what my mate bought. Also, I’d read about some of the cheaper ones not doing the crimps quite right.
But that was ages ago, so do some research and shop around. There's plenty of $20 ones out there these days and I've seen them at hardware box stores too so it should be easier to return if you get a dud item.
I only paid about $60 . . not the $160 at this link.
https://www.toolmart.com.au/teng-ttcp04.html
The Teng crimper came with three sets of jaws.
It also does the now more common colour coded plastic insulated terminals just fine with the insulation in place but I just think they look a bit ugly (and non Lotus) even if the crimp is OK.
The terminals JB linked to is also what I use & with the clear insulation sleeves that just push into place.
I think you can get black or coloured sleeves too.
« Last Edit: Thursday,August 08, 2019, 11:53:03 AM by GavinT »
« Reply #18 on: Thursday,August 08, 2019, 12:20:02 PM »
Certified, where are you mounting your fuel pump on your TC?
Fallbrook, Ca
Electric fuel pump installed under the carbs and bolted to the chassis. Rubber isolation mounted.
Facet style pump? If so, I would mount the pump as low the bottom of the tank as possible to get maximum suction head.
Checked the Facet website and this is what I found.
We recommend that you mount the fuel pump no more that 12 inches from the fuel supply (gas tank). All our Electronic fuel pumps will push fuel rather than pull fuel. Some pumps only have suction limit of 12 inches, therefore you should mount as close as possible to the tank.
« Last Edit: Thursday,August 08, 2019, 12:34:18 PM by Grumblebuns »
« Reply #19 on: Thursday,August 08, 2019, 12:21:57 PM »
That only happens with a cold solder joint. I always pre-tin the end of the wire then heat the connector and solder once there is flow. After cooling shrink wrap the wire and connection.
Been doing it for 30 years on boats, cars and RC stuff. Never had a failure.
The new crimp connectors are very good. If I was doing this professionally I would own one.
« Reply #20 on: Thursday,August 08, 2019, 12:30:58 PM »
Anyone know maximum height the Facet pumps can draw fuel from (maximum height above the bottom of the tank)?
[/quote]
It’s the electric fuel pump RD sells. I don’t have the pump specs on me at the moment but I looked up the lift and should be fine. I’ve got one in my Elan S1 and it’s also above the tank with no operating issues.
« Reply #21 on: Thursday,August 08, 2019, 01:46:34 PM »
The discussion of soldering prompted me to remind myself of what Carroll Smith, author of Prepare to Win, Tune to Win, and Nuts, Bolts, Fasteners and Plumbing Handbook (he says he wanted to call it "Screw to Win" but demurred), and probably other books on race car preparation, said about the subject. BTW, I recommend all of them. In Prepare to Win Carroll Smith sez:
Quote
I am fully aware that the claims made for the best of the low tension solderless terminals are valid and that the aircraft industry now uses precious little solder. I am just reactionary enough to believe that a properly soldered connection is better than the solderless terminals that I can afford. Use resin cored solder and an electric soldering iron (the pistol grip Weller gun is the best). The soldering iron must be both clean and well tinned. Clean it by dipping in a resin cup or rubbing on a piece of sal-ammoniac. Good terminals are supplied pre-tinned so precious little solder is required to make a good connection. A good mechanical joint is required. Excess solder not only looks nasty and increases the electrical resistance of the joint but the excessive heat necessary to deposit too much solder may well embrittle the wire leading to breakage at some later time. The right amount of heat, applied at the right place (on the back side of the terminal), not on the wire) with the right amount of solder (very little) will produce a perfect joint every time. Practice makes perfect. If you decide against soldering use only aircraft certified Sta-Kon solderless terminals - the automotive stuff is junk. In either case vinyl heat shrink tubing will not only improve the appearance of the assembly but will go a long way toward preventing short circuits.
I post this only for information and those who might interested and not to be on one side or other of any argument that hopefully will not happen. I, myself, use the cheap automotive terminals that he says are junk. An engineering buddy of mine once told me how impressed he was Sta-Kon terminals. I also was told by a friend who saw Carroll Smith's son's race car which was maintained by Carroll himself that he apparently didn't practice what he preaches (without knowing more, I'm willing to believe he had time or other constraints).  Anyway discussions of soldering vs crimping on terminals don't seem to come up very often so I thought I'd throw Carroll's view of it into the mix.
« Last Edit: Thursday,August 08, 2019, 01:54:22 PM by BDA »
« Reply #22 on: Thursday,August 08, 2019, 02:15:59 PM »
I attached a schematic of what I did on my car for the electric water pump, fuel pump, and ignition.  I also added an anti run-on valve which my car did, maybe because it is 10.3 compression and has Hitachi SU carbs.  The solenoid opens the manifold after the carbs to atmosphere, which kill the engine.  Works well for me.  I don;t know whether anyone else needs that feature.
I hope it is useful.
« Reply #23 on: Thursday,August 08, 2019, 02:23:37 PM »
I have never had a soldered joint fail.  My friend who races will only crimp battery terminals.  He has had too many fail.  Good quality wire is flexible, even where it is crimped.  Soldered battery wire goes solid and creates a stress point where the solder ends.  YMMV
« Reply #24 on: Thursday,August 08, 2019, 08:38:47 PM »
Ahhh . . the great Carroll Smith. His “Prepare to Win” is particularly good and anyone restoring a Europa would find it helpful for the practical side of things, methinks.
The solder v crimp discussion can get pretty “heated” in some circles. I mean . . . now we have to choose between Carroll Smith and NASA?  :FUNNY:
Anyway, like Certified, I’d also been soldering terminals for 30 years and never had a failure.
EDIT: Now that I think about it, make that 50 years!
I recall part of what convinced me was the consistency & quality of the crimper connection. Also, I previously neglected to mention that my mate also showed me his fancy (but not expensive) wire stripper.
This wire stripper also ensures quite precise & repeatable stripping of the wire.
But I’d agree that if all we’re doing is the occasional terminal here an there, it’s difficult and perhaps pointless to break the tried and true habit of a lifetime.
The other thing that convinced me was that, for many jobs I wanted to do, it would mean I had to plug in the soldering iron, arrange all the flux condiments, solder, iron stand etc. and do the soldering in some awkward upside down position under the dash . . tinning, dabbing and trying not to melt nearby wires & stuff.
If you’re doing the terminals on a bench, likely that doesn’t matter as much.
« Last Edit: Thursday,August 08, 2019, 10:14:36 PM by GavinT »
« Reply #25 on: Friday,August 09, 2019, 05:43:57 AM »
Gavin, you should be ashamed of yourself!  ;)
Offline gideon
« Reply #26 on: Friday,August 09, 2019, 09:28:07 AM »
You need special tools and a lot of pressure to crimp those heavy battery cables.  Here's a video somebody made to demonstrate a 10 ton hydraulic battery cable crimper :
https://www.youtube.com/watch?v=xyXMJIgpeyE
Short version - the hydraulic crimper was $40 on ebay, and did a much better job than his old battery cable crimper.
« Reply #28 on: Friday,August 09, 2019, 07:32:59 PM »
I should . . but ask yourself if I am.   :D
I probably have half a dozen wire strippers but the pic below is the one I like the best. I can’t remember the brand and there are plenty of knock-offs around.
If considering one of these, the stripper lives and dies on the quality & precision of the cutting jaws. The good ones have ground jaws that are very sharp. They’ll even do the tiny CAT6 Ethernet wires with no damage to the copper strands.
There’s also some clever self-adjusting ones available too. I discounted those because they wouldn’t produce a dead square & clean cut. They also don’t properly remove, say an extra 2mm slice off a wire you’ve already stripped.
But everyone has their favourites, so that’s cool.
Actually, someone should to start a “Tool Talk” thread.
There’s so many good tools, artful adaptions & contraptions out there that fellow Europa home gamers could share.
« Last Edit: Friday,August 09, 2019, 07:57:51 PM by GavinT »
