The speedo in my car wasn't working anymore, so instead of trying to find the unobtanium gearbox parts, I started to look for another option.
1st option was a GPS speedo. Cheap and cheerful, but:
- Potentially no speed signal in tunels (there's not many where I'm at) but maybe more important;
- GPS speedo doesn't seem to be legal and speedo needs to be hard wirded?
The Smiths electronic speedo's are very cool, but expensive.
I had a look around and settled with a marine/truck application from VDO (SingleViu).
This is an 80mm speedo with white needle, just size as the original Smiths the Europa's came with.
Here's how I did my install:
1st I had to determine where pick up the signal for the sensor.
I decided on the disc bolts for the hub (I ground them blank)
As you can see, the bolt from the steering arm to the hub was too short to add a bracket:
...so I picked up a longer one:
Fabbed a bracket for my sensor:
And then, put it all together:
Initially I was worried how to adjust the sensor within 1.0mm from the bolt heads, so I used a bigger sensor (M12) which allows a bigger gap (up to 2mm).
In the end it was super easy to meat with the fine thread on the sensor, so I could have used one size smaller sensor:
The wiring for the speedo was straight forward:
12V continuous
Ground for meter
Ground from meter to sensor
12V Ignition
Signal from sensor
The sensor wiring I did as follows:
Ground (the one coming from the speedo)
12V (I took from acc on)
Signal to meter
The prgramming of the meter was real easy. Just imput the amount of pulses per km and you're done.
I used a tape measure to measure 2 rev of the wheel (I think it was 320cm) = 8 pulses.
Pulses/km = (100000cm / 320cm) x 8 = 2500
Total cost:
The VDO meter was €95
The speed sensor €8 (I used LJ12A3-4-Z/BX, NPN - NO)
Various pieces of wire, angle iron, bolt, etc +/- €20.
Very happy with the result. It all works perfect, but I will make a new beefier bracket in the future as on rough roads, the signal fluctuates a bit. On smooth roads, spot on (tried upto 120km/h).
