Author Topic: Interior fuse box location TC  (Read 1764 times)
« on: Tuesday,July 30, 2019, 05:00:33 AM »
I didn't take enough pictures when I disassembled my car.  Just confirming this is the proper location of the interior fuse box (behind the flap on the center console)
Re: Interior fuse box location TC
« Reply #1 on: Tuesday,July 30, 2019, 05:10:20 AM »
This one? I got it off the documents section, electrical.
« Reply #2 on: Tuesday,July 30, 2019, 05:32:26 AM »
That’s where it goes.  Stupid, because you have to remove the center console to change a fuse, but that’s where it belongs.  If you don't attach it to anything and let it hang, you may be able to fish it out from behind the center console flap.  I screwed mine to the center tunnel fiberglass.
« Reply #3 on: Tuesday,July 30, 2019, 05:39:03 AM »
There should be a vertical metal bar attached to the fibreglass tunnel, RHS with two holes in it.
Two self tapping screws hold the fuse box to two  black clips which engage the self tapping screws.
« Reply #4 on: Tuesday,July 30, 2019, 06:45:19 AM »
This is what the fuse box looks like attached. I don't recall if it ever came with a cover.
Offline tedtaylor
    • TaylorMadeClassicCars
« Reply #5 on: Tuesday,July 30, 2019, 07:24:05 AM »
corner "flap" of console easily bends up to expose fuse panel.   no need to remove console.
TED
'13 Evora S
« Reply #6 on: Tuesday,July 30, 2019, 07:40:12 AM »
My fuse box had a cover.
Speaking of fuses, I remember reading somewhere to use British fuses. I think it has something to do with how or when they blow. I'll see if I can find it.
Edit: I found this thread on an MG forum. https://www.mgexp.com/forum/mgb-and-gt-forum.1/british-vs-american-fuse-ratings.2338834/
« Last Edit: Tuesday,July 30, 2019, 07:46:34 AM by BDA »
« Reply #7 on: Tuesday,July 30, 2019, 08:38:40 AM »
Mine appears to be forward of the flap and has a cover. Still don't know what that toggle switch in the upper middle of the picture does. Can confirm it is NOT an ejector seat.
« Reply #8 on: Tuesday,July 30, 2019, 09:11:56 AM »
I found some more information on British vs American fuses. This is probably where I first read about the difference.
« Reply #9 on: Tuesday,July 30, 2019, 09:20:38 AM »
Maybe there are machine guns behind your turn signals or oil tank in the back for people following you!  ;D
Seriously, might it be a fan override?
« Reply #10 on: Tuesday,July 30, 2019, 09:34:01 AM »
White wires.
Maybe a secret anti-theft switch that disables the coil?
« Reply #11 on: Tuesday,July 30, 2019, 10:20:01 AM »
Always use the correct wire colours (and stripe colour) when working on your harness.  It makes future troubleshooting so much easier.
Never assume the PO did so.  In fact, you can pretty much count on the fact they won't have.
« Reply #12 on: Tuesday,July 30, 2019, 11:38:52 AM »
My bet is it is a switched earth to turn the radiator fan on.
« Reply #13 on: Tuesday,July 30, 2019, 05:24:28 PM »
Thanks guys! Surf I like your install and will find a way to replicate it. BDA interesting insights on fuse differences.
« Reply #14 on: Tuesday,July 30, 2019, 07:37:58 PM »
I had an Alfa Spyder once that shot out an oil slick. Not on purpose though.
It is not a cooling fan override or a kill switch. I have a mystery shutoff valve on the right fuel tank, my best guess is it was once connected to that, but isn’t any more.
Where does one get Lucas color coded wire? Ace Hardware doesn’t carry Brown with Pink Tracer wire.
