Thanks everyone. I spent the morning with a file and sandpaper. I filed the mounting boss for the caliper very slightly and sanded 3 of the 4 pads. The rotors are still not centered. Dakazman, my rotors are closer to the outboard side, but I'll put that down to tolerances of everything. I filed so little on the mounting boss, that I'm not sure if I did anything. However, the good news is with the filing and sanding the rotors turn freely with only a very slight sound of the rotor rubbing the pad on both sides. My understanding is that this is normal. Without the pad the rotors turn with no noise. As I'm just an enthusiastic amateur my plan is to have all of my work checked by a professional before the car is put on the road so if anything is wrong it will be fixed before I run into a wall.
I have reassembled the rear brakes and that went smoothly. As I have the self adjusting brakes, which I have read don't work real well I took advantage of having everything apart and drilled an access hole in the backing plate if I ever have to adjust the brakes manually.
For setting the end float on the front hubs I know the manual says to use a dial gauge. The mount for my dial gauge is not long enough to work. I read on the Knowledge Base that the end float can also be set by tightening the hub nut to 5 lbs and then back off to the next flat to align the cotter pin. I did that and it seems fine. Anyone set the end float that way?
My next project is to finish the brake lines.
Thanks again,
Sherman
