Author Topic: Alternative shock bushings  (Read 696 times)
« on: Wednesday,July 17, 2019, 07:20:44 PM »
Those stupid #@%& AVO shock bushings don’t last very long.  The originals failed after being mounted on the car before it had even been driven!  AVO acknowledged they had a bad batch and sent me a new set for free.  At 9K, the front uppers started failing.
I have ordered these replacements instead:
https://www.merlinmotorsport.co.uk/p/heavy-duty-suspension-bush-for-avo-coilovers-avo-ra2-bb
For you hardcore-crazy types, there are these:
https://www.merlinmotorsport.co.uk/p/replacement-spherical-bearing-circlips-for-avo-coil-over-dampers-avo-com8
Just something to keep in mind if you have AVOs — which are otherwise excellent shocks.
Re: Alternative shock bushings
« Reply #1 on: Wednesday,July 17, 2019, 07:33:18 PM »
I don't have AVOs but I've considered them as a possible alternative at some point. I appreciate the update!
« Reply #2 on: Wednesday,July 17, 2019, 10:12:34 PM »
9K isn't a very reasonable life, is it ?  I know they are cheap enough to replace but that's not the point, you'd expect them to last for years on any normal car.
I don't know if it would work with AVOs but when I refurbished my Europa several years ago with (supposedly) OEM dampers I replaced the rubber bushes with the metal/rubber composite bushes that you use for the front wishbones. They obviously don't have as much rubber in them but they are tough and stayed working until I bought the Protech dampers several years later.
« Reply #3 on: Thursday,July 18, 2019, 02:05:54 AM »
JB, I had a similar situation with my front upper  AVO shocks on my Elan S1. The rubber crumbled to pieces after a couple thousand miles. I contacted Dave Bean about this and sent photos and a sample. AVO said it was the first time they had seen this but supplied free replacement bushings. So far the new ones are fine.
I have AVO coil overs front and rear on my Europa. Will be watching them.
Offline FrankWissman
« Reply #4 on: Thursday,July 06, 2023, 12:25:34 PM »
Has anyone tried poly parts from Energy Suspension? I don't see an exact match for a 73 TC, but we are willing to cut 'n drill as needed.
