Author Topic: Noise from cam wheel/axle  (Read 844 times)
Offline Lyngeled
« on: Wednesday,July 10, 2019, 02:28:47 AM »
Hi
now the runs much better  ;D But there is some noise from the cam wheel or axle. I think it could be a bearing, but I must investigate it som more. Do some of you have an idea?
Regards
Re: Noise from cam wheel/axle
« Reply #1 on: Wednesday,July 10, 2019, 03:59:57 AM »
Hi Bobbie,
 Is the car stationary or moving? Engine or drivetrain?
Offline Sandyman
« Reply #2 on: Wednesday,July 10, 2019, 04:07:34 AM »
Bobbie, if I understand what you are saying, the noise is coming from the area in the engine where the cam shaft and alternator pulley are. Is this right?
Sandy
Offline Lyngeled
« Reply #3 on: Wednesday,July 10, 2019, 04:39:16 AM »
Yes it is stationary, I only hear it when standing behind it. And it commes from the cam pulley, sound like, but must be behind. But I thought that could be inside the pulley, because I changed the belt and changed the distance between the two discs (maybe some of the washers is loose). Suddenly I think that it could be too much tension on the belt, it is little tight.
« Reply #4 on: Wednesday,July 10, 2019, 05:24:20 AM »
You would have to work at it to get the alternator belt too tight so I don't think that's it.
Could you describe the sound? Better yet, could you post a little video with sound?
« Reply #5 on: Wednesday,July 10, 2019, 06:39:31 AM »
The belt should deflect if pushed firmly in the centre between the two pulleys.
It sometimes can be help isolate where the noise is coming from if you remove the belt and briefly run the engine.
Using a long screw driver can also help isolate noises.  Hold one end to your ear and touch the other to various points on the engine.
Offline Lyngeled
« Reply #6 on: Saturday,July 20, 2019, 03:00:42 AM »
Hi
I removed the one disc and the.belt. The sound was gone, it was a loose washer 😊
« Reply #7 on: Saturday,July 20, 2019, 08:03:54 AM »
Glad you have it pinned down, pictures would help us follow along a little better. When do you think you’ll be running again?
Offline Lyngeled
« Reply #8 on: Saturday,July 20, 2019, 10:54:30 AM »
Here, maybe it's the belt but it's not a bearing. I am "running", just not too far at the time 😁
I am beginning to get more used to my "new" car.
There's another sound, and I located that to be this uj. It's making a knocking sound almost all the time and get rather hot. I am thinking if I should avoid longer trips?
Offline Lyngeled
« Reply #9 on: Saturday,July 20, 2019, 11:00:26 AM »
Uj
Offline Lyngeled
« Reply #10 on: Saturday,July 20, 2019, 11:02:04 AM »
Car
« Reply #11 on: Saturday,July 20, 2019, 11:13:11 AM »
The u-joints are small and can wear sooner than you might expect.  There are a number of poor quality u-joints out there as well.  I have had brand new ones knock right out of the box.  These three brands have worked well for me: GKN, Spicer (reboxed GKNs), and SKF.  Avoid GMG!
Early days with the car, CHECK THE DRIVESHFT SHIMMING !!
