Author Topic: TC distributor orientation  (Read 426 times)
Offline Fotog
  • 72 Twin Cam
« on: Friday,July 05, 2019, 06:14:03 AM »
The distributor in my Twin Cam has a cap with screws rather than clips, and is oriented such that one screw is directly toward the head and the other is toward the side of the car.  The one nearer the head is extremely difficult to access.  No bent screwdriver, or even the smallest 90 deg. ratcheting one, can access it.  There's just no room to turn it.  I can reach it from above, through the gap between the intake for the no.1 and 2 cylinders, but due to the way the distributor is oriented outward at about 45 degrees from vertical to the block, it's not good.  After only about 3 times taking the cap off, the screw is pretty buggered-up and I'm not sure it would make it through another try.
So my plan is to re-orient the distributor, and I just want to run my idea by y'all to make sure I'm thinking this through correctly.
I'm thinking:  rotate the distributor body through 90 degrees (counter-clockwise, I envision).  Leave the rotor in its current  position.  With firing order of 1,3,4,2, the wire that was in the 2 position has now rotated ccw such that it's in the former no. 1 position and the rest follow suit.  So, change the wires so that what was no. 2 goes to cyl. no.1, 4 becomes no. 2, 3 becomes 4 and 1 becomes 3.
Then use a bulb to set approximate static timing so that the points just open for cyl. no. 1 at 5 deg BTDC, start it, and set the timing more precisely with a timing light.
I think this is right, unless someone can point out some error in my thinking.  Agree?
Vince
Re: TC distributor orientation
« Reply #1 on: Friday,July 05, 2019, 06:35:11 AM »
Sounds fine.  The distributor points cam is symmetrical.
Just as an aside, some air-cooled VW distributors have points cams where #3 cylinder is a few degrees retarded from the others.  This is because #3 cylinder’s cooling air flows through the oil cooler and that cylinder runs hotter than the others.
Just a bit of useless trivia.
Offline Fotog
  • 72 Twin Cam
« Reply #2 on: Friday,July 05, 2019, 09:42:04 AM »
Thanks!  Interesting, too.  It never occurred to me that there could be any possibility that the cam isn't symmetrical.
V
