Author Topic: It finally arrived with pictures  (Read 1575 times)
Offline Nero
Re: It finally arrived with pictures
« Reply #15 on: Tuesday,July 02, 2019, 10:15:34 AM »
Foam filters do catch fire easily. A single backfire can be enough. With cars made of gfrp this can be the end of your car.
« Reply #16 on: Tuesday,July 02, 2019, 10:37:33 AM »
I used to be a track rat with a Lotus Exige S for many years. I saw more Lotus Elise and Exige’s catch fire than I care to remember. It was amazing how fast they burned once catching fire.
I good friend of mine had an Exige but from the factory for racing. Had the factory installed fire suppression system built in by Lotus. Burned beyond salvage at Summit Point. No crash, no hitting a wall or going off track. Something caused a fuel leak and the car burned in a few short minutes even with the suppression system fully operating.
Personally, I always install SS braided fuel lines, have Airboxes covering the carbs and keep a fire extinguisher in the passenger area at all times. One good backfire and you will probably be in flames faster that you can believe.
« Reply #17 on: Tuesday,July 02, 2019, 10:52:18 AM »
I like air boxes as well.  Any backfire is simply sucked back in.
« Reply #18 on: Tuesday,July 02, 2019, 12:38:42 PM »
Hmmm. I suppose I should have been suspicious when the filter cleaning process involves spraying it with (highly flammable?) solvent and finishing it with sticky (highly flammable?) oil.
One of my Lotus mentors cautioned me against separate air filters for the two carbs, saying it was a recipe for imbalance. What does the tribe like for aftermarket air filters?
« Reply #19 on: Tuesday,July 02, 2019, 01:09:10 PM »
Both the stock systems on the Renault and TC/S Europas actually work very well.  The only improvement would be to fit aftermarket bell mouths to a Stromberg equipped TC/S.  That said there are two issues with the stock systems: dirt and high air temps.
Road dirt and dust seems to be the most concentrated right where both systems suck in their "fresh" air.  Period tests commented on the fact that the Renault air filter became restrictive fairly quickly.  I run a twin Dell equipped crossflow with a TC/S air box and filter.  I find that I have ti change the air filter every 2K to 3K kilometres or performance suffers.
Equally spooky is the Lotus engineers unerring ability to find the hottest possible intake air.  Intake air temps can get up to 120°F+!  Building an air box and accessing air down low towards the front can make a huge difference.
My plan is to fit an air filter from a Jag XJ6 series 3 and duct it to cold air just behind the driver's seat.  That will draw cool air and the larger filter area will last much much longer.
What should Mr. A. Spares do?  Fit an airbox and a remote filter down low on the driver's side.  Here are some air boxes for single Webers:
http://www.bitsofitaly.com/cold-air-box-intake
(The MGB set up would be perfect)
https://www.efihardware.com/products/c59/Air-Boxes
(you have to cut out the base plate to suit)
When choosing a filter bear in mind that more surface area (lots of pleats) is better than bigger holes (more dirt along with the more air).
Offline Sandyman
« Reply #20 on: Tuesday,July 02, 2019, 01:19:30 PM »
John, I agree with you about getting cooler air. In my mind what you are describing using the air space in front of the left side fuel tank. Is this what you are describing?
« Reply #21 on: Tuesday,July 02, 2019, 01:52:36 PM »
There is an article/thread from Peter Boedker which analyses the air intake temperatures for his TC and how he set it up to draw air from underneath the car.  From what I can see a few others (myself included) have followed that lead and made up some ducting to take air from underneath.
I don't do a great mileage in mine but having said that, the filter is far cleaner than you'd expect from the system description
thread here http://www.lotuseuropa.org/LotusForum/index.php?topic=2658.0
and a couple of shots of my installed system, one from the engine bay and the other from underneath.  This is on a TC but it should work on most cars with some tinkering I'd have thought.
« Reply #22 on: Tuesday,July 02, 2019, 02:04:28 PM »
Nicely done, Brian!  :beerchug:
« Reply #23 on: Tuesday,July 02, 2019, 02:41:27 PM »
I have bought the parts for my custom Airbox, trunking and large capacity filter. You’ll need to wait until I’m ready to install before I reveal, but cool air flow is the requirement.
Offline JR73
  • Banks Europa S2
« Reply #24 on: Tuesday,July 02, 2019, 03:53:02 PM »
Was it a Mk1 Motorsport Elise (what the Mk1 Exige was made to look like) by any chance? A very good friend has one and used to compete in a series made up predominantly of those and I don't think there was a car on the grid that hadn't been on fire! - fuel rail vibrating loose was the most common cause which allowed atomised fuel to fill the engine bay. We nicknamed my mates car "Jerry Lee" because of how many times it went up in flames! Annoyingly not the same cause each time but he had a repeat order set up for replacement extinguishers! - luckily it was never too badly damaged.
Foam filters aren't the best choice as has already been mentioned and it's also worth considering carrying an extinguisher - better to have at least tried to put it out and save your pride and joy than wish you had one whilst watching it burn (I hate seeing things burn).
Sorry for the high jack/off topic deviation.
« Reply #25 on: Tuesday,July 02, 2019, 04:03:16 PM »
As described......
Offline JR73
  • Banks Europa S2
« Reply #26 on: Tuesday,July 02, 2019, 04:32:48 PM »
A Mk2 Exige, that's not a nice thing to see.  :'(
« Reply #27 on: Tuesday,July 02, 2019, 04:40:31 PM »
Very sad...  :'(
« Reply #28 on: Tuesday,July 02, 2019, 04:50:35 PM »
Learn from others mishaps. Don’t risk fire.
Offline aspares
« Reply #29 on: Wednesday,July 03, 2019, 04:05:46 PM »
Thanks for all the feedback. Got the plates and have a few hours drive time on it. Great car, a blast to drive, shifts great excellent oil pressure does not overheat (its been pretty hot here) and has really good acceleration.
I did put the K and N air filter on and will work on an air box this winter.
I would like to get a new carpet set, tires , Lotus hub caps and a new or really good center consul. I doubt that I will ever put the A/C in but open to thoughts on that. Also thinking of getting new tires, I have not checked but the tires are at least 10 years old. Looking at these Blockleys would they be the correct size??  https://www.blockleytyre.com/product/165hr13
also https://www.blockleytyre.com/product/185-70VR13  or
https://www.blockleytyre.com/product/235-60VR13
Thanks for any other ideas
