Author Topic: A funny thing happened on the way to the fuse box  (Read 429 times)
« on: Wednesday,June 26, 2019, 09:52:14 PM »
As you know I’m in the middle of a 2K trip with the Europa.  Had a bit of time and I troubleshot a couple of long term, intermittent issues.  The first was the occasional DNF of the AC, and the other of the same with the backup camera.  Believe or not, both were caused by fuses with intermittent continuity due to vibration.  Both from the same fuse box next to the engine.  Might have to switch over to blade type fuses if it happens again.
Offline 1970EuropaGuy
    • Lotus Europa Restoration
Re: A funny thing happened on the way to the fuse box
« Reply #1 on: Wednesday,June 26, 2019, 10:31:41 PM »
I switched over to blade fuses when I first bought my car, Best thing I did!
Have fun on your travels. the weather is fabulous on the coast.
