Author Topic: Splash panel replacement  (Read 1392 times)
Offline TCS4605R
Re: Splash panel replacement
« Reply #15 on: Sunday,June 30, 2019, 12:35:47 PM »
For my front and rear splash panels, I cut and bent 0.020" aluminum sheet (Lowes or Home Depot) to fit the panel, then covered the aluminum with wax paper (as a release agent) then applied (3) layers of 3/4 ounce fiberglass matt.  Then I cut and shaped the cured fiberglass a necessary and applied one coat of black epoxy and (2) coats of matt black 2-part.  I used stainless steel button head screws instead of pop rivets to secure them in place.
74 TCS
