Author Topic: Splash panel replacement  (Read 1393 times)
Offline 1970EuropaGuy
    • Lotus Europa Restoration
« on: Monday,June 24, 2019, 09:22:42 AM »
I'm replacing all of my splash panels (correct name?) as the originals are warped badly and don't seal. What are you folks using for material? I've been thinking of aluminum as I can easily source it but it may not be flexible enough?
Re: Splash panel replacement
« Reply #1 on: Monday,June 24, 2019, 09:52:06 AM »
Somewhere I had some black scrap plastic sheeting that was about the same thickness as the original fiberboard. It works well but aluminum would work well, too. It depends on what you have access to.
« Reply #2 on: Monday,June 24, 2019, 09:53:15 AM »
 Hey 70, the close-out panels probably can be made of .032 aluminum. Maybe cut them slightly smaller and edge the outer and top sides with sliced tubing or pipe wrap glued on.  I made mine from glass mat.
« Reply #3 on: Monday,June 24, 2019, 10:22:14 AM »
Some good ideas, thanks. I'll likely go with aluminum, do like the idea of edging it with tubing. Of course glass mat would work well and I have lots of that lying around.
« Reply #4 on: Monday,June 24, 2019, 10:31:02 AM »
 The only other item is safety. If the aluminum broke loose it could slice into the cabin .
« Reply #5 on: Monday,June 24, 2019, 11:13:51 AM »
I reused mine and re-riveted in. The OEM install used tape to seal the seam between the fiberglass body and the panel. I did the same.
RD sells a replacement made of plastic. Good idea.
« Reply #6 on: Monday,June 24, 2019, 12:19:12 PM »
An interesting thought. Wouldn't want to feel unsafe in a Lotus Europa! :beerchug:
I feel like playing with fiberglass today so I'll give that a try.
« Reply #7 on: Monday,June 24, 2019, 12:20:31 PM »
Certainly the easy way to go but once they get shipped to Canada, taxes paid and exchange rate the price can get crazy.
Offline Bodzer
« Reply #8 on: Monday,June 24, 2019, 01:13:31 PM »
Steve Veris is making a set for my S2. Might be worth an email. steve.veris@sbcglobal “dot” net
« Reply #9 on: Monday,June 24, 2019, 01:18:53 PM »
Some years back I was faced with the same situation...
The factory "closing plates" in the wheel arch were made of a thick durable paperboard coated with a black resin similar to the finish you would see on the backside of a standard roofing shingle.
DIY...I used the old ones as a template...Got some spare shingles I had laying around...Presto!
« Reply #10 on: Monday,June 24, 2019, 01:57:47 PM »
Great idea Lou. Where were you a couple of days ago when I was revising in the old ones?? I would have used your idea!
Offline Gary t
« Reply #11 on: Monday,June 24, 2019, 08:07:34 PM »
I used 1/4 polyethylene sheet (puck board) extremely tough, and I had it in my shop. Two good reasons to use it.
Gary
54-1173
Gary Toffelmire
54/1173
Offline Steve_Lindford
    • The time is...
« Reply #12 on: Tuesday,June 25, 2019, 12:14:45 AM »
Does paint adhere to aluminum?? Im not sure it would stand up to having stones and dirt thrown at it...
« Reply #13 on: Tuesday,June 25, 2019, 04:09:13 AM »
I made mine from 3/32” ABS.  It was easy to do using the old cardboard ones as patterns.
Steve Veris sells them as well.http://www.lotus-europa.com/forsale.html
RD also sells them.
« Reply #14 on: Wednesday,June 26, 2019, 05:06:23 PM »
I did mine out of black ABS as well. Cuts easy with fine tooth jig saw. One side is textured. My originals were junk. I used $1 store poster board for templates. Turned out nicer than I thought it could.
