Author Topic: Removing the molding flange  (Read 1808 times)
Re: Removing the molding flange
« Reply #15 on: Wednesday,June 19, 2019, 10:10:49 AM »
Hi Chuck,
 It looks like you are using cloth. For what it's worth, it may/will print through. You may not notice right away but after it's painted it often shows. .
Nope. It WILL print through! Rather than using cloth, use veil (or gauze -  same thing just different names for it) on the exterior surfaces. Maybe even multiple layers. Cloth is harder to work with so I would suggest heavier mat everywhere else.
Offline Chuck Nukem
« Reply #16 on: Wednesday,June 19, 2019, 10:12:45 AM »
Hi Chuck,
It is actually a combo of chopped strand mat with a veil cover on the top. I remember your story BDA about how you did cloth on your car and the grief it caused.
« Reply #17 on: Wednesday,June 19, 2019, 10:25:28 AM »
Interesting stuff, then! It really didn't cause me much grief but the guy who did it said he tried everything to get it not to print in the paint and couldn't. There are places on my car where you can see it if you look. It's not terrible but it would have been better not to have done it. A layer (or two or three) of veil would have been much better.
« Reply #18 on: Wednesday,June 19, 2019, 02:55:32 PM »
I circled the spots in red. I believe this is a vestigial part of the mfg process. To clarify by molding I am referring to the actual mold used to make the body. I believe this seam is where the bottom body mold was joined to the top. I am not talking about anything on the side of the car. I was curious if anyone has ground these smooth to reduce drag under the car. It is probably a negligible benefit, but if there was ever a time to do it....
JB I agree, for S2 painting it black is the way to go.
Sorry, totally misunderstood what you meant. Now I see. Unless your building a race car I’m not sure I would make the effort to sand these down to make flush. Plus, they are sacrificial in case you hit something low.
Offline gideon
« Reply #19 on: Wednesday,June 19, 2019, 07:53:57 PM »
Chuck, maybe the flange acts as a sort of mini spoiler.  There might not be any aerodynamic advantage in removing it.  I don't have any actual evidence for or against that point of view but, on the other hand, neither does anybody else.  In any case, removing it is more work, so if you decide to leave it alone then you can direct your attention to the next job on the list.
Offline Chuck Nukem
« Reply #20 on: Wednesday,June 19, 2019, 08:00:29 PM »
The forum has talked sense in to me. If mine was all chipped up it might be a different story. I am going to leave it. I have enough stuff to do on this thing already! :)
Offline TCS4605R
« Reply #21 on: Wednesday,June 19, 2019, 08:58:58 PM »
The molding flange at the front and rear of my car had a lot of 'voids' between the upper and lower sections, so I filled the void space with fiberglass matt and resin and sanded it smooth with a rounded contour.  You can see this in the attached photo.  I too thought of sanding it smooth, but it looked like you would loose some strength in the joint, so I tried to reinforce it instead.
Tom - 74 TCS
Offline Chuck Nukem
« Reply #22 on: Sunday,June 23, 2019, 07:34:49 AM »
Your underside looks amazing! What kind of paint did you use for it?
Offline TCS4605R
« Reply #23 on: Sunday,June 23, 2019, 11:55:37 AM »
I used a black 2-part epoxy primer then two coats of 2-part SEM Hot Rod HR014 - see attached photo of the SEM cans.
74TCS - 4605R
Offline TCS4605R
« Reply #24 on: Sunday,June 23, 2019, 11:59:42 AM »
Attached is another photo on the underside.
Offline Sandyman
« Reply #25 on: Sunday,June 23, 2019, 12:46:41 PM »
Tom, What a great job!! It looks damn near bullet (stone) proof. Thanks for the information on the products you used, it will come in handy when I start doing body work.
Sandy
« Reply #26 on: Sunday,June 23, 2019, 01:00:41 PM »
Very nicely done. Looks great!
« Reply #27 on: Sunday,June 23, 2019, 01:10:26 PM »
Looks great Tom.
I haven’t touched the underside except to do some spider repairs. Anything to protect the glass from contaminates is a good thing. I’m definitely going to look into it.
