Author Topic: WTB right rear lower wishbone half  (Read 1115 times)
« on: Tuesday,June 04, 2019, 11:49:14 AM »
I need a straight right rear lower wishbone half. I have a set of S2 lower wishbone arm but there is interference with the shock.
Thanks!
Re: WTB right rear lower wishbone half
« Reply #1 on: Tuesday,June 04, 2019, 01:31:19 PM »
I assume you are also posting on the yahoo list?  Or is there a rush of curbing incidents?
I have a set of the arms with the welded-on spacer for the shock.  Is this the style you are after?  If so, I would gladly trade for your S2 set.
« Reply #2 on: Tuesday,June 04, 2019, 01:44:06 PM »
Yep, that was me. I thought the ones I had but when I checked the caster on the right, it was out. I'll clean up the pair I have and spray it with black rattle can - or whatever color you want. I'll also check the dimensions before I send them but they are perfect to look at them. There are bushings in them but they a probably the originals so you'd probably want new ones. When I get them cleaned up, I'll pm pictures to you.
Thanks!!
« Reply #3 on: Tuesday,June 04, 2019, 07:02:48 PM »
Here's the ones I have that I think are for a TC/S:
https://jbcollier.smugmug.com/Lotus-Europa/i-CLD2pq3/A
https://jbcollier.smugmug.com/Lotus-Europa/i-xxQHrrb/A
https://jbcollier.smugmug.com/Lotus-Europa/i-PK9JTtv/A
They are not for sale but I would exchange for good earlier ones that would fit my S1.  All lower arms are dimensionally the same but later ones spread out wider between the mounting points.
« Reply #4 on: Tuesday,June 04, 2019, 08:06:19 PM »
I could have ground some off my arms to make room for my shock but I prefer using the proper arms if possible or aftermarket tubular arms if not.
If you have a nice pair that measure out properly I'll definitely be interested. In the meantime, I'll measure the early pair I have.
« Reply #5 on: Wednesday,June 05, 2019, 03:03:13 AM »
« Reply #6 on: Wednesday,June 05, 2019, 05:30:43 AM »
Thanks Certified, Ted emailed me last night.
« Reply #7 on: Wednesday,June 05, 2019, 06:19:12 AM »
If there are some available in the US, go for those.
