Author Topic: horn location  (Read 638 times)
Offline Fotog
  • 72 Twin Cam
horn location
« on: Tuesday,June 04, 2019, 07:53:41 AM »
I don't have a horn in my twin cam.  Where is it properly located?  I see it in the parts list, but not on a diagram.  And should there be two, a high note and a lower frequency horn?  Seems so from the parts list.
Thanks!
Vince
Re: horn location
« Reply #1 on: Tuesday,June 04, 2019, 08:38:32 AM »
I don't remember where the horn was mounted originally. I would guess it would have been on the floor in front of front trunk somewhere. I would not try to be original in that regard. My memory of the original horn was that it was very weak - not as loud as my old VW Beetle horn. Air horns are common on many Europas and r.d. sells a nice compact horn.
With the size of a Europa, it's not always easy to be seen. If you can't be seen, you must be heard!
Re: horn location
« Reply #2 on: Tuesday,June 04, 2019, 08:47:31 AM »
Next to the spare wheel on the inside of the left front wheel arch.
Offline 1970EuropaGuy
    • Lotus Europa Restoration
Re: horn location
« Reply #3 on: Tuesday,June 04, 2019, 10:39:16 AM »
I replaced my wimpy S2 horn with a small air horn. It's still wimpy by air horn standards but is definitely quite a bit louder than the original.
Re: horn location
« Reply #4 on: Tuesday,June 04, 2019, 12:29:47 PM »
Horns are located in the left front upper fender arch...
For safety reasons , I would recommend a system louder than the stock version. I also run the exhaust w/ no muffler...just a header and resonator. Better to be heard, if not seen.
Re: horn location
« Reply #5 on: Tuesday,June 04, 2019, 01:26:30 PM »
Location, location, location.  You do not want to be be beside or slight behind an adjacent vehicle.  In front or behind.  If I'm beside, I have one hand on the horn.  I use very loud air horns: just twin trumpet Fiamms driven by a compressor off a 70's Citroen.  The compressor is huge.  I have my horns mount off a front bumper bolt so there are closer to the grill.
I also ride motorcycles and scooters.  One friend wears the most outrageous set of bright plaid pants and has a sticker on his scoot saying "Loud Pants Save Lives".
Offline Fotog
  • 72 Twin Cam
Re: horn location
« Reply #6 on: Wednesday,June 05, 2019, 06:48:05 AM »
Thanks for the input.  I ordered a pair of air horns and I'll figure out somewhere good to mount them in the front of the car.
