Author Topic: Capped-off Pipe in Frame: What am I looking at here?  (Read 836 times)
« on: Sunday,June 02, 2019, 07:14:19 AM »
DPO's handywork in the "V" of the frame. I can't find this pipe anywhere in the parts manual. What am I looking at here?
Thanks,
Offline tedtaylor
    • TaylorMadeClassicCars
Re: Capped-off Pipe in Frame: What am I looking at here?
« Reply #1 on: Sunday,June 02, 2019, 07:21:12 AM »
heater hose?
TED
'13 Evora S
« Reply #2 on: Sunday,June 02, 2019, 07:28:17 AM »
heater hose?
That was my guess. It would seem to want to go to the "heater control valve" which is... where? I think my DPO may have removed the heating system entirely. Being a summer-only car I have never attempted to turn the heater on.
t
« Reply #3 on: Sunday,June 02, 2019, 07:42:37 AM »
Yes. heater pipes.  You can see the one on the other side as well.
« Reply #4 on: Sunday,June 02, 2019, 09:04:14 AM »
Where does the heater valve tee into the cooling system in a TCS, normally?
t
Offline tedtaylor
« Reply #5 on: Sunday,June 02, 2019, 10:02:33 AM »
right off the thermostat housing.   one plug for temp sending unit, the other for heater control valve.
TED
'13 Evora S
« Reply #6 on: Monday,June 03, 2019, 12:51:15 AM »
I think this is fairly standard. What you can't see here is the pipe heading down towards the rear Y section and on to the steel tubes in the chassis.
« Reply #7 on: Monday,June 03, 2019, 02:54:49 AM »
Here is another view:
« Reply #8 on: Monday,June 03, 2019, 04:50:53 AM »
Thanks guys;
Yep, heater valve is clearly missing on mine. No ski trips in this Europa. I'll have to check if I even have a heater core. I suspect weight obsessed PO probably took that out too.
« Last Edit: Monday,June 03, 2019, 04:55:05 AM by surfguitar58 »
