Author Topic: 70 S2 0044Q  (Read 77754 times)
Offline Sandyman
Re: 70 S2 0044Q
« Reply #360 on: Monday,February 15, 2021, 04:54:40 PM »
Thanks for the input John. I am not planning to plumb directly into the carb. Just blow air into the air filter area. Still to big for that?
Re: 70 S2 0044Q
« Reply #361 on: Monday,February 15, 2021, 06:49:26 PM »
No, not at all, just thought you could reduce the size a bit and make it more aesthetically pleasing.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #362 on: Monday,February 15, 2021, 07:16:48 PM »
Great feedback.  Thanks. How much closer to the roof do you think I can go? I am trying to mimic the front grill but upside down.
Re: 70 S2 0044Q
« Reply #363 on: Monday,February 15, 2021, 09:37:28 PM »
I'd go as close as you can.  The air flow is clean over the roof.
Some inspiration:
Offline Sandyman
Re: 70 S2 0044Q
« Reply #364 on: Monday,February 15, 2021, 09:43:50 PM »
Love the pictures. With the way the Europa trunk opens any ideas on how to make a quick disconnect?
Re: 70 S2 0044Q
« Reply #365 on: Tuesday,February 16, 2021, 06:36:05 AM »
Normal vent screen out, foam seal for paint protection, moulded in "hooks" at the rear and a padded hook on a thumbscrew at the front.
Re: 70 S2 0044Q
« Reply #366 on: Tuesday,February 16, 2021, 08:05:17 AM »
Fiat Abarth from the 60's.
This one is being used for cabin ventilation but it looks smart enough, I thought.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #367 on: Tuesday,February 16, 2021, 09:17:40 AM »
Gavin, thanks for the input.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #368 on: Friday,March 05, 2021, 09:05:40 AM »
Restyled air scoop. All suggestions welcome.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #369 on: Friday,March 05, 2021, 09:08:00 AM »
This style allows the Rear deck to be lifted with out removing scoop.
Re: 70 S2 0044Q
« Reply #370 on: Friday,March 05, 2021, 10:03:08 AM »
Being able to lift the rear deck sounds like a good, practical attribute.  I know I'd be more tempted to try something like this if I didn't have to remove it every time I opened the engine cover.  It also gives you more options for the fixing hardware and the chance to hide most of it under the deck.  I wonder if a taller, narrower "mouth" wouldn't provide better flow into the "neck" of the air scoop, but I'm probably just picking nits.  I think it looks promising.
Re: 70 S2 0044Q
« Reply #371 on: Friday,March 05, 2021, 10:44:44 AM »
Wow, looks good.  You’ll get plenty of air through that.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #372 on: Friday,March 05, 2021, 11:13:19 AM »
Thanks JB. Gideon, I am trying to mimic the look of the front grill to give it a "period correct" look. If you look at the air flow over the roof (Look up Wind Tunnel test) it stays very close to the roof. The next job is to design the under side attachment and deflector to bathe the carb. air cleaner in cool air. I will also flair the bottom edge so I can add foam to protect the paint.
Sandy
Re: 70 S2 0044Q
« Reply #373 on: Friday,March 05, 2021, 11:58:51 AM »
Make a mold, sell 'em, retire early, smoking expensive cigars!
Offline Sandyman
Re: 70 S2 0044Q
« Reply #374 on: Saturday,March 20, 2021, 05:21:05 PM »
Lunch break at the ski hill today. She got lots of attention.
