Author Topic: 70 S2 0044Q  (Read 76729 times)
Re: 70 S2 0044Q
« Reply #285 on: Friday,July 17, 2020, 04:45:55 PM »
Your fan switch is wired correctly.  There is no low speed, just on and off.
What colour are the wires to the turn signal switch?  GW and GR?
Offline Sandyman
Re: 70 S2 0044Q
« Reply #286 on: Friday,July 17, 2020, 05:22:34 PM »
Wires into flasher are LGP and G. With the blower fan the 2 feed wires are green and green yellow. The green is live all the time. The green yellow goes to the switch and never has power no matter where the switch is set.
Re: 70 S2 0044Q
« Reply #287 on: Friday,July 17, 2020, 09:35:34 PM »
Could the LGP wire really be a LGN wire?
What are the wire colours at the column mounted turn signal switch.  GW, GR and ??
The fan is wired correctly.  G is fused intone power.  GY is the fan ground wire.  It goes to the switch which has a B (ground) and a RB (rad fan relay ground trigger).
Offline Sandyman
Re: 70 S2 0044Q
« Reply #288 on: Saturday,July 18, 2020, 01:15:07 PM »
I have got the Turn signals working. The LGN and KGR looked the same. Now need to figure out how to rewire Indicater light on dash.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #289 on: Saturday,July 18, 2020, 04:23:56 PM »
Electrics at 95% operational. Replaced Flasher unit, indicators lights all work. No power to dash indicator yet. The blower fan only likes to run with engine running. Rad fan turned on by itself when coolant reached the required temperature. New fuel tank in and plumbed. Throttle cable set so that it is fully open when peddle is touching its stop. Choke and heater cables will be installed tomorrow. Buff and install bonnet/hood as well.
Sandy
Re: 70 S2 0044Q
« Reply #290 on: Saturday,July 18, 2020, 05:36:43 PM »
Sounds good!
Are you using a two terminal, or three terminal flasher?
Offline Sandyman
Re: 70 S2 0044Q
« Reply #291 on: Saturday,July 18, 2020, 06:04:35 PM »
I am using a 2 terminal flasher unit. Will a 3 terminal give a feed to the dash light?
Re: 70 S2 0044Q
« Reply #292 on: Saturday,July 18, 2020, 09:01:42 PM »
Yes.  The third terminal feeds the warning light.  I like Trico HD flashers as their flash rate isn't load dependant.  HD-12 is the two terminal version while HD-13 is the three.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #293 on: Tuesday,July 21, 2020, 10:37:58 AM »
Thanks for the flasher input John, installed and working. I put another mile on the car. Took her to the Land rover/ British car guy in town he fiddled with the carb. tune, running great! I need to find some paved level ground to fiddle with the alignment and ride height. I am the one in the white shirt.
Re: 70 S2 0044Q
« Reply #294 on: Tuesday,July 21, 2020, 11:28:36 AM »
Great news, Sandy! I hope you get on the road with your baby soon!
Re: 70 S2 0044Q
« Reply #295 on: Tuesday,July 21, 2020, 11:32:58 AM »
Looking good!
Offline Sandyman
Re: 70 S2 0044Q
« Reply #296 on: Tuesday,July 21, 2020, 01:04:36 PM »
Even better with the door on. Thanks to my nephew. Also got passenger seat and trunk/boot lid on.
Re: 70 S2 0044Q
« Reply #297 on: Tuesday,July 21, 2020, 04:01:58 PM »
Holy Doodle, it's a car!
Get a four wheel alignment.
Europas are a delight when set up properly -- still don't lift when cornering at the limit -- but a bit of a nightmare otherwise.
Re: 70 S2 0044Q
« Reply #298 on: Tuesday,July 21, 2020, 04:02:53 PM »
Duh!
You have the Spyder chassis.  That's a real improvement.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #299 on: Tuesday,July 21, 2020, 04:16:32 PM »
Thanks John, she needs a bath and a vacuum. With all the adjustments in the Spyder chassis I need to get her on a rack and set up everything. I have the specs from Spyder. The English carrier pidgeon must be encountering headwinds. The new driver side door latch is still on it's way. Last thing I need to certify.
