Author Topic: 70 S2 0044Q  (Read 77669 times)
Offline Sandyman
Re: 70 S2 0044Q
« Reply #105 on: Friday,April 03, 2020, 11:33:02 AM »
John, the 4 wheel disc upgrade I have from Spyder seems to be mostly Elan +2 components. Does this change any of the information and help you are so graciously providing?
Sandy
Re: 70 S2 0044Q
« Reply #106 on: Friday,April 03, 2020, 01:08:07 PM »
Probably but would have to see the components to know for sure.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #107 on: Friday,April 03, 2020, 01:25:25 PM »
John, What would you like pictures of? Please be as specific as possible so I can get the right angles. I have the invoice with Spyders suppliers numbers.
Thanks
Sandy
Re: 70 S2 0044Q
« Reply #108 on: Friday,April 03, 2020, 01:59:37 PM »
Are the hubs aluminum?
Did they come with bearings?  Seals or felts?
Offline Sandyman
Re: 70 S2 0044Q
« Reply #109 on: Friday,April 03, 2020, 02:21:36 PM »
Aluminum hubs, bearings and felts
Offline Sandyman
Re: 70 S2 0044Q
« Reply #110 on: Friday,April 03, 2020, 02:33:54 PM »
Another progressive day in the shop. Balmy 7 deg C / 45 deg F sunny day. Assembled both rear suspensions, nothing tightened yet. Out of curiosity I put the rear brakes on. 2 rights could be wrong! Need to get a left rear caliper. Hopefully Spyder Chassis will correct this.
Sandy
Offline Sandyman
Re: 70 S2 0044Q
« Reply #111 on: Friday,April 03, 2020, 02:37:26 PM »
I am always a little apprehensive when the job is done and there are parts left over. Any guesses?
Re: 70 S2 0044Q
« Reply #112 on: Friday,April 03, 2020, 03:53:25 PM »
Can you post detailed photos of the hubs and felts?
Offline Sandyman
Re: 70 S2 0044Q
« Reply #113 on: Friday,April 03, 2020, 04:08:01 PM »
John, as requested.
Re: 70 S2 0044Q
« Reply #114 on: Friday,April 03, 2020, 06:56:23 PM »
Assemble without the felts first and check as I laid out above.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #115 on: Friday,April 03, 2020, 07:04:28 PM »
Thanks John.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #116 on: Saturday,April 04, 2020, 01:42:10 PM »
Hi all. I am installing the front hubs and I don't have the gauge to check the end float (as per manual). Are there any other methods? Like tightening the hub to the point of binding and then backing off the nut +1 flat?
Thanks
Sandy
Re: 70 S2 0044Q
« Reply #117 on: Saturday,April 04, 2020, 03:47:53 PM »
That's pretty much the way I do it. I tighten the nut while turning the hub till it is tight enough that it hard to turn, then I loosen the nut while still turning the nut till it turns freely. As soon as it turns freely, I put the cotter key in the nearest flat.
If you want to put some numbers to that, many years ago, I used a beam torque wrench while tightening. It would usually get tight around 10 ft-lbs more or less, probably less. You want to make sure the bearings are fully seated on their races before loosening the nut.
Other people may have their own methods, but that's mine and it seems to work for me.
Offline Sandyman
Re: 70 S2 0044Q
« Reply #118 on: Saturday,April 04, 2020, 03:57:41 PM »
BDA, Many thanks. More hiccups in the assembly. I was shipped 2 right side rear calipers and front rotors with incorrect hole spacing.
Re: 70 S2 0044Q
« Reply #119 on: Saturday,April 04, 2020, 05:18:05 PM »
Bummer! Hopefully they will send you correct parts while you send them the wrong ones...
