Nero, what alignment specs are you using? The S2 spec for rear toe is 3/16" in. to 0. The TC spec is 1/4" to 1/8" in. Using this site (
https://robrobinette.com/ConvertToeInchesToDegrees.htm) and a tire diameter of 23.1" which should be close to the diameter of a 185/70-13 tire, I find that 3/16" toe in is equivalent to .466 degrees. Unless I made a mistake (or the calculations this website makes is seriously flawed), your .5 degrees toe in is actually a little more than specified. Maybe somebody can check me on this.
Do you have a fully adjustable front suspension (i.e. spherical rod ends on the inboard side), you would need to adjust them for more caster. Otherwise, JB is right. Something is bent. Since the stock front A-arm pieces are designed to bend and absorb energy in the even of an accident, finding one that is bent is not that unusual.
