Author Topic: Replacing speedometer cable  (Read 871 times)
Offline 1970EuropaGuy
    • Lotus Europa Restoration
« on: Wednesday,April 03, 2019, 11:32:33 AM »
I just picked up a new speedometer cable from RD Ent.
I'm assuming I could tape the new cable to the old and pull it through. Any words of wisdom? Pull from front to back or back to front? Remove the old cable completely and attempt to feed the new one? Have a beer and hire somebody?
Re: Replacing speedometer cable
« Reply #1 on: Wednesday,April 03, 2019, 11:47:59 AM »
Attach a 12v wire to the speedo end of the old cable using a loop and cable ties and feed it down the chassis tunnel into the engine bay. Then attach the new cable to the wire using a loop and cable ties, and pull the new wire back through the tunnel and up behind the dashboard.
There is not enough room behind the dashboard to feed the long cable through from that end.
If the inside is stripped out, it does not matter from which end you start.
« Reply #2 on: Wednesday,April 03, 2019, 11:50:30 AM »
Thanks, makes sense.
