Author Topic: Gearbox in neutral still engaged?  (Read 2394 times)
Re: Gearbox in neutral still engaged?
« Reply #15 on: Wednesday,April 03, 2019, 09:17:31 PM »
I dunno, my limited slip diff idea was a bit lame too.  It sounds to me like a linkage issue.  I would disconnect the linkage at the box, shift it into neutral manually and then see what's up.
Offline Lyngeled
« Reply #16 on: Wednesday,April 10, 2019, 05:39:50 AM »
Hello
I have fixed it!  :trophy: It was one of the forks in the rear under the little cover. I just had to figure out how to assemble it again and then it worked. I used both hands and one foot to test.
It went out of the chassis because I couldn't get the rear cover of.
« Reply #17 on: Wednesday,April 10, 2019, 06:01:25 AM »
Glad you got it fixed! That's got to be a relief!
Offline Lyngeled
« Reply #18 on: Wednesday,April 10, 2019, 01:50:06 PM »
Yes, very much ;D
Offline Lyngeled
« Reply #19 on: Wednesday,April 10, 2019, 10:46:23 PM »
I have an idea of what the cause was, because I had winch lying back there and it was partly resting on the roof going to the gear lever. And I often sit in the trying learn how to use the gear stick. It especially difficult to get into first and second. But last time I couldn't get it into reverse, that was the winch, I think, and that could too have pushed it out one or more of those forks.
