Author Topic: Gearbox in neutral still engaged?  (Read 2393 times)
Offline Lyngeled
« on: Tuesday,April 02, 2019, 04:34:02 AM »
Hi
I tired to lift up one rear wheel to turn the gears but when it's in neutral the engine still turns when the wheels turn, what's that? Maybe it is a synchro ring or it is still in the last gear. I haven't tried to roll the car, today I will do it, then I will see if I can push it in neutral as I could before.
Regards
Offline Europa73
Re: Gearbox in neutral still engaged?
« Reply #1 on: Tuesday,April 02, 2019, 05:06:09 AM »
HI,
I had a similar thing happen to me.
The issue for me was that a selector fork had slipped and remained engaged when the car was in neutral.
« Reply #2 on: Tuesday,April 02, 2019, 09:07:14 AM »
I had a similar sounding thing happen to me. There is an extended disucssion about the topic here: http://www.lotuseuropa.org/LotusForum/index.php?topic=2710.msg26148#msg26148
I finally used an adjustable broom stick to hold the clutch in while I rocked the car back and forth ion neutral. It didn't take much force to break free and was less risky than turning the starter over in my tiny driveway. Let us know how you make out.
Offline Sandyman
« Reply #3 on: Tuesday,April 02, 2019, 09:18:32 AM »
Good old broomsticks more than an engine compartment prop.
« Reply #4 on: Tuesday,April 02, 2019, 12:01:52 PM »
First try lifting up both rear wheels.  It's rare but it could have a limited slip diff.  I fit one to mine.
Still a problem?  Then I'm afraid Europa 73 is right and there is an issue in the transaxle.  The engine is not connected to the wheels when the car is in neutral, even if the clutch plate is frozen to the flywheel.  Hopefully you just need to remove the rear cover -- moderately easily done -- to sort the issue.
« Reply #5 on: Tuesday,April 02, 2019, 12:17:01 PM »
 Are you sure that the gear change rod is not worn or hitting something and it is actually moving the selector shaft sticking out of the gearbox?
I had a very worn UJ on a gear change long long ago, and selecting gears was luck.
Offline Lyngeled
« Reply #6 on: Tuesday,April 02, 2019, 12:40:38 PM »
What would I do when both wheels are up? I think the wheels should turn opposit ways,  but I think I remember that it didn't last time.
« Reply #7 on: Tuesday,April 02, 2019, 01:11:07 PM »
If you have an LSD fitted, both wheels will turn the same way.
Offline 2766R
« Reply #8 on: Wednesday,April 03, 2019, 02:12:01 AM »
Now that you mentioned it.....
« Reply #9 on: Wednesday,April 03, 2019, 06:10:56 AM »
Install gas struts from your engine cover. Richard sells a kit or there are plans here: http://www.lotus-europa.com/manuals/index.htm. You won't regret it!
Offline Sandyman
« Reply #10 on: Wednesday,April 03, 2019, 07:11:48 AM »
RD also has a strut kit.
Offline Sandyman
« Reply #11 on: Wednesday,April 03, 2019, 07:18:36 AM »
Back to the original thread. Bobby, any luck with getting the transmission unstuck?
Offline Lyngeled
« Reply #12 on: Wednesday,April 03, 2019, 03:17:45 PM »
No. I tried rocking it but I couldn't feel anything happening. Now I will push out the car to make the floor nicer to lie on, but continue working on the carburetors. After that I will return to the gear box. But I will open the front cover and look into it. I liked to open it up to see what is happening but it is not the best time for me now.
Offline Lyngeled
« Reply #13 on: Wednesday,April 03, 2019, 03:25:43 PM »
BTW I felt something stopping the stick from moving forward a couple of times then it came loose again.
And I use a fiberglass surfer sail batten instead of a broom stick, it suits the car I think 😊
« Reply #14 on: Wednesday,April 03, 2019, 06:38:34 PM »
I realized I may have sent you down the wrong path when JB noted a stuck clutch disk would not keep the wheels from turning if the trans is in neutral. Sounds like a different problem.
t
