Author Topic: Brake light switch  (Read 5770 times)
Offline 1970EuropaGuy
    • Lotus Europa Restoration
Re: Brake light switch
« Reply #15 on: Saturday,February 23, 2019, 08:25:30 AM »
Sandyman, I picked it up at Princess Auto on Vancouver Island. For the US neighbours, Princess Auto is a little like Harbor Freight except 2 or 3 times more expensive.
I had hoped to put the light under the overhang but it doesn't quite fit. Anyway, I think it looks OK. Does work well with the stripe!
« Reply #16 on: Saturday,February 23, 2019, 08:51:33 AM »
That's a very neat mod, it looks so good it could be original if Lotus had heard of high level brake lights back then.
It fits in so well that I can imagine you going through shelves of lights to find one that fitted the stripe !  :)
Offline Sherman Kaplan
« Reply #17 on: Saturday,February 23, 2019, 12:00:08 PM »
That looks great.   How did you run the wiring to the light?
Thanks,
Sherman
Offline Sandyman
« Reply #18 on: Saturday,February 23, 2019, 02:28:34 PM »
Thanks Europaguy, Princess Auto in Owen Sound ON. (close to me.) I will copy if you don't mind.
Offline tedtaylor
    • TaylorMadeClassicCars
« Reply #19 on: Saturday,February 23, 2019, 03:16:18 PM »
Thanks,
Sherman
Very easy.   The under lip air vents provide a void to fish the wires across the top and down the side sails to the brake light switch.   very easy mod.
TED
'13 Evora S
« Reply #20 on: Saturday,February 23, 2019, 03:52:05 PM »
Thanks,
Sherman
I drilled a small hole through the fibreglass to run the wires inside. Another small hole in the firewall to pass the wires into the engine compartment. Certainly going through the vents would work as well but with this light it mounted flusher with the drilled hole.
It's very bright, I think a good mod for all of us in today's SUV world.
« Reply #21 on: Saturday,February 23, 2019, 05:04:20 PM »
I installed mine under the roof lip. Bent some sheet metal into a 90 degree angle, secured light to metal, and metal to car with a couple dabs of RTV. Ran the wires as Ted Taylor did. Mine are wired into the turn signals too.
« Last Edit: Saturday,February 23, 2019, 05:06:53 PM by andy harwood »
« Reply #22 on: Friday,March 01, 2019, 08:08:16 AM »
A photo of the brake light lit. It's very bright, should wake people up!
« Reply #23 on: Friday,March 01, 2019, 07:26:13 PM »
That looks very bright! Anything to be more visible is a good thing!!
