Author Topic: Door latch fibregalss backing  (Read 5004 times)
Offline 1970EuropaGuy
    • Lotus Europa Restoration
Re: Door latch fibregalss backing
« Reply #15 on: Monday,February 04, 2019, 08:41:07 AM »
Thanks for all the images and insights. I'm planning on working on this project the next few days, will post an update.
TCS4605R, if you have the time a PDF would be great.
« Last Edit: Tuesday,February 05, 2019, 09:13:44 AM by 1970EuropaGuy »
Offline TCS4605R
« Reply #16 on: Monday,February 04, 2019, 04:12:19 PM »
Attached is a PDF showing the fiberglass door lock cutouts for my right hand door - more or less accurate - no two Lotuses are the same!
74 TCS - 4605R
« Reply #17 on: Monday,February 04, 2019, 04:50:02 PM »
74 TCS - 4605R
Thanks Tom,     :beerchug:
I'll check measurements but this looks great. I know what you mean about no two Lotuses looking the same, I find that in much of my restoration research.
 I'll compare with what I have.
« Reply #18 on: Monday,February 04, 2019, 05:32:50 PM »
Thanks Tom , that pdf will definitely guide me to finishing up some unknowns.
« Reply #19 on: Tuesday,February 05, 2019, 07:34:02 PM »
Just finished making an aluminum back plate. A little rough but it's a prototype at this stage and will get sandwiched in glass anyway.
Should work well, thanks for all the help with photos, drawings and suggestions.
I'll post the finished project when I get there. Time for a hard earned beer! :beerchug:
« Last Edit: Tuesday,February 05, 2019, 07:35:42 PM by 1970EuropaGuy »
Offline Yellowbelly
« Reply #20 on: Wednesday,February 06, 2019, 12:29:41 AM »
Does anybody know what these door latches originally came from as i need a replacement passenger unit (drivers side for those on the other side of the pond :))?
Offline gideon
« Reply #21 on: Wednesday,February 06, 2019, 07:44:33 AM »
Round off the corners on that backing plate, otherwise you'll get a stress concentration and the possibility of cracking at the corners.
« Reply #22 on: Wednesday,February 06, 2019, 07:54:28 AM »
This looks very close.
They made several million of them.
« Reply #23 on: Wednesday,February 06, 2019, 09:04:30 AM »
Thanks, good idea. I'm learning as I go on this project.
Offline rascott
« Reply #24 on: Wednesday,February 06, 2019, 07:22:56 PM »
i believe some elan models used the same latch.
i had found the same part number listed, as i was looking.
Offline Yellowbelly
« Reply #25 on: Thursday,February 07, 2019, 12:32:31 AM »
Unfortunately the other side is completely different to the mini ones
