Author Topic: Replacement Fan Motor  (Read 1353 times)
Offline E Paul
« on: Tuesday,January 29, 2019, 12:15:19 PM »
The fan motor for my radiator is making bearing worn out noises. The original motor from our friends in Hethel died circa 1985 and was replaced with an exact replacement that was from Delco. This one is now sick. I do not know the part number. Does anyone know if there is an exact replacement motor currently available or do I need to modify something to fit? Suggestions?
I want to hit the road running come spring so this job comes right after NSX timing belt replacement is done...current winter project.
Thanks,
Paul
Re: Replacement Fan Motor
« Reply #1 on: Tuesday,January 29, 2019, 12:33:49 PM »
I have an "orignal" replacement fan. I bought it many years ago as a replacement for my original fan but I have to say, I don't think it looks exactly how I remember my original fan looked, but it wouldn't surprise me if there were different suppliers. It is attached to an original fan shroud. There is some surface rust but mostly it's just dirty. I just tested it and it works. If you're interested, PM me.
Offline JR73
  • Banks Europa S2
« Reply #2 on: Wednesday,January 30, 2019, 01:22:29 PM »
Very similar fans (never checked to see if they are the same) where fitted to Esprits - later Esprits had plastic multi element blades but they can be removed/swapped. - might stand a better chance of getting one of those?!
Offline E Paul
« Reply #3 on: Wednesday,May 01, 2019, 07:10:24 AM »
Finally got around to investigating this. Turns out that it was just rubbing a bit on the housing. A thwack with the heel of my hand and all quiet again. On to other issues so that it is driveable once the rains end.
« Reply #4 on: Wednesday,May 01, 2019, 10:32:01 AM »
I build a wooden mold to put into the round fan cowl (with a flat bit cut out) to get squashed cowls round again.
I have to keep the wooden mold dry as it swells up and won't fit if the wood gets wet.
I made it from 2 offcuts of 7"x2" I had lying around.
« Reply #5 on: Thursday,May 02, 2019, 04:07:10 AM »
E Paul, your under good guidance however one item that may be at fault is that the at the fan to motor shaft is a small roll pin that can wear out . It’s a pin thru shaft .
Offline E Paul
« Reply #6 on: Thursday,May 02, 2019, 09:09:59 AM »
I had checked that. Its solid.
