Author Topic: Side window lift slide channel  (Read 1565 times)
« on: Sunday,December 30, 2018, 08:33:05 AM »
Does anyone know a good method to install the electric window lift slide onto a new side window?  It appears to be installed with just a piece of rubber between the metal slide and the window.
Offline rascott
Re: Side window lift slide channel
« Reply #1 on: Sunday,December 30, 2018, 01:58:32 PM »
on my '69s2 there is a nylon roller that fits the channel.
sorry-
 i see now you speak of what actually holds the window glass. that does appear to have been rubber, though it is kinda stiff and vaugely flexible now.
« Last Edit: Sunday,December 30, 2018, 04:56:16 PM by rascott »
« Reply #2 on: Sunday,December 30, 2018, 07:54:46 PM »
Yes.  I just broke the window and the replacements do not the track, so I have to figure out how to attach the old one.
Offline Rosco5000
« Reply #3 on: Monday,December 31, 2018, 08:25:29 AM »
I haven't replaced a Europa window before but I did work in a boat window factory as a glazer for a few years and it is possible that it is a pressure fit with rubber to the window regulator.  A local automotive window shop may have new rubber to help you out as lots of cars are attached that way.  I am pretty sure my old Saab was like that too and my Mini.
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
« Reply #4 on: Monday,December 31, 2018, 10:12:22 AM »
I thought that was the case.  I just don’t want to break it again putting that on the window!
Thanks, and Happy New year.
« Reply #5 on: Tuesday,January 08, 2019, 08:20:38 AM »
I fitted the channel onto the bottom of the glass with the rubber (which was not a tight fit) and used silicone to assemble it with. That seemed to work ok.
« Reply #6 on: Tuesday,January 08, 2019, 12:00:12 PM »
Thank you.
Offline lotus-62
  • Location: Holland (also known as dutchland, land of the dutch)
« Reply #7 on: Thursday,January 10, 2019, 12:31:57 PM »
I used the inner tyre from a bike (thin rubber) soapy water and a rubber hammer.... good luke, btw I made that little nylon wheel detachable from the motor arm so it is easier to get the glass in/out (I can keep the motor and arm on position, take out the nylon wheel and lift the window out)
