Hi All .. finally putting the body back on the chassis but have hit a problem. the shell no longer wants to sit down over the backbone of the chassis . I have used closed cell foam soundproofing that is 10mm thick , that seemed to be reasonable based on thickness of original material ?. Anyone else had problems , are they all a really snug fit , any suggestions before i take it off and use a thinner gauge of foam Thanks guys
